HMS Beagle - Occre by TedR
Yes, it's just like you say, sand down the bits with the orange x-marks so they blend into the keel part..... On the paper instructions, on sheet D, the third photo along gives a reasonable idea of how to fair those blocks at the stern. (You need to remove so much material that it's better to sculpt it with a hobby knife to start with.)
I wish I'd taken more photos of my build as I went now!
Thank you
If you sand too much, it will become obvious when you lay a plank atop that bulkhead, but no biggie. Just add scrap pieces of wood to build up the low bulkhead and fill in the gap, fair your built-up bulkhead(s) until the loose fitted plank shows a nice fit, then proceed as usual. This might change the geometry ever so slightly, but who cares. Nobody will ever know but 'you'! ;)
Got it. I'll post a photo when I finish.
I'm working on the stern. When I go to install the second plank it is jumped in the middle from the false keel. Should I glue it in place.like.thisnthen sand.thebresulting plank or grind down.the keel first17750065977359128954822629832598.jpg
Sand the keel down first so that plank lays flat, and makes a nice smooth continuous run with that first plank.
Has there been any further news on your wife? No doubt the doctors are doing "some more tests". We're all hoping for some more positive results.
We're going for a cat scan Friday morning. We had to go to Lancaster CA to get it this week. One million illegal.aliens were dumped into los Angeles county by.the previous administration. Getting medical services for natural citizens is difficult.
I feel your pain. I would say to write your Governor about this... but we both know where 'that' would go!
I’m sorry to hear about the situation. I wish you all the best with the scan on Friday, and hoping for good results.
That said, I’d kindly suggest we keep discussions here focused on shipbuilding. Posts like this can quickly become political, and we should avoid that so the forum remains welcoming and on track for everyone.
Cleaned and trimmed the interior bulwark planks.
I respect your desire to keep this site focused on modeling and shipbuilding. I apologize if I overstepped your boundaries.
Someone ratted me out while I was using my plank bending iron. The big cheese came by and said it isn't allowed because I could.burn myself and they would get into trouble. I'm going to try and soak the wood enough to bend it. If that doesn't work I'm getting sneaky.
Tell that paranoid nut job that your plank bending iron functions as a medical testing machine. If you can feel a burn, it's proof that you're still alive and that all is well with you.
Sometimes it is best to 'NOT' use moisture, only heat! You're not a fool but maybe the so-called 'Big Cheese' is! Thumbs up to Pepite 1/60. I wonder if your 'Big-Cheese' person has a hot water heater, or a stove at home? If so... that person could easily hurt themself too! @#$!
Are clothes irons allowed? I use a small 'travel style' clothes iron more than I use a plank bender. My plank bender is only used on really tight, short bends, on small scale models that my travel iron can't effectively handle. Your Beagle may not have any bends that short and tight. I'll glue the end of a plank to the bow, about 1/4-1/5 inches worth. After the glue cures, I pull the planks around the bulkheads as far as I feel I can safely go without breaking the plank, then iron it out to shape. I'll glue the plank, pull it some more, heat it, rinse/repeat until I'm done with the tight bends. If worse comes to worse... simply put you planks under your hot dinner tray when supper is served, but be careful. That tray might be hot! LOL
I was able to install a plank by just soaking it in room temperature water so I can continue
I've almost finished one side of the bulwarks. I believe I'm going to have to replace the last piece for the bulge at the bow. The rest is pretty clean.IMG20260403184047.jpg17752669428559082150356316242214.jpg
