Making your own Ropes
Hi Kuba,
I’m new to this forum and this is my first post. I’ve been trying to make ropes for the past two weeks, but it’s been a complete disaster. So far, I’ve only managed to waste thread and time with the PL4-3 machine from Mr. Aleksei Domanov.
As you can see in the photos, the ropes come out badly twisted and lose almost all their tension. When I tried twisting them in the opposite direction, they turned into a massive tangle, forcing me to stop the machine.
Honestly, for the price I paid, I expected something much better. At this point, I don’t think it’s good for anything at all. Now the main issue will be the return process, since I live in the USA and Mr. Domanov is in Poland.
I’m writing in English in case someone else here owns the same machine and might be able to help. I’d really appreciate the chance to connect with you and hear about your experience using it. I bought a PL4-3, and so far, all I’ve accomplished is wasting thread.
To be honest, I’ve felt like throwing it in the trash—but after reading your posts, I see you speak very highly of it. If you don’t mind, I would greatly appreciate any advice you can share. You can even reply in Polish, or send a private message if you prefer.
I’ve attached some photos so you can see the kind of "ropes" the machine is producing for me. Any help would be greatly appreciated.
Thanks in advance,
Jacek Castro
That’s what happens if I don’t wind the yarns, threads and rope tight enough.
Even on this rope walk I’m using now will do this if I don’t wind tight enough.
You’ll be amazed how tight you have to wind the rope.
Let me go get something out of the bin.
These images from a few days ago. The first 1mm rope I made on the rope walker.
From what I’ve learnt here and experimentation in the past. I knew straight away I’d did not wind the rope tight enough.
Not as bad as your rope but fairly similar. When I cut this rope it was like a spinning top and just curled up into a mass mess.
Keep in mind this is captured in a mobile phone so not the best cleanest image.
I cut this rope and it did not uncurl. I did cure this rope as I do with all ropes I now make.
If I did not cure the rope apx half to 1cm would where I cut would unwind.
By curing the rope it stops any unwinding and also helps to bind the yarns, threads and rope tight.
I followed the details Ben mentioned in the link that Skeef66 posted on curing ropes.
I think I read that link Skeef66 shared from start to Finnish apx 4 times. Every time I read it the more I learnt and what I did not understand I asked here.
I also like to add I was attempting to make rope a bit thicker on the PL4 I own by using all 4 bobbins and a core.
That what I was starting to experiment with. I was not getting much success though. Found it very difficult to get all 4 bobbins evenly tensioned. And I found the yellow gear assembly was a bit weak, hence stripping one of the gears. Which I rectified by using cad software and making a much stronger gear out of ASA filament. However the final results were like yours. Unwind when I cut
As a general contractor, architect, and engineer, I’m fairly comfortable with the technical side of machinery, and I’m always learning something new each day to have the opportunity to expand my knowledge. As I explained in another post, I have encountered several setbacks during the attempt, and I have run into a few challenges that I’m still trying to work through. For instance, I had a bobbin come loose while the machine was running, and I’ve also noticed that the wheel holding the three bobbins seems to wobble from side to side rather than rotating smoothly on its axis. This appears to affect how the gears engage, as they sometimes feel like they are slipping and the noise becomes unbearable.
Sorry about incorrectly underestimating your mechanical experience with tools! It's one of the hazards of these forums. You never know, so you tend to presume the person asking a question doesn't know as much they do unless they tell you! :D
Bobbins should not come loose when the machine is operating. Perhaps one wasn't tightened enough. The felt washers on either side of the bobbins are important. The pressure from the wing nuts against the felt washers creates the friction that regulates the tension on the strand as it comes off the bobbin.
The planetary wheel (the big one that rotates the bobbins) should not wobble. Everything on the machine should rotate smoothly and not wobble or create a lot of noise from grinding gears. It sounds like there may be a problem with the assembly of your machine. Mine came partially disassembled. As I recall, it was important that some of the parts were installed in the correct orientation. Perhaps a wheel is on backwards or something. I can't diagnose it from here, but it from your description you have a mechanical problem that should be easy enough to figure out by watching the thing run. (Slowly... you don't want to break something!)
Phillipsart is correct that the PL4's capacity is limited by the amount of thread that can be wound on the bobbin and thus also by the thickness of the thread. If one is going to make large diameter scale line, the PL4 probably isn't the best machine to select.
There isn't any way I know of to really wind thread on a sewing machine bobbin evenly without a bobbin winder. Every sewing machine has one built in these days, but for our purposes, if a sewing machine isn't handy, a stand alone bobbin winder is the tool for the job. They are not at all expensive and make quick work of loading a standard bobbin evenly and under the tension you set. Mine runs on AA batteries.
See: https://www.amazon.com/SINGER-Portable-Automatic-Shut-Off-Compatible/dp/B09Q7QVNQQ/ref=sr_1_8?adgrpid=1332608665312386&dib=eyJ2IjoiMSJ9.CneY0bYpmhoUFQtkMGleIHjAITc0bfnv08VL2BeYXSacCgyJsu1p617sKPLCuBG3SwkJTNfoPhuy-cmlQ4KYzM0THoUzDuD1-v_MPHwKQ8kifn3K13YyZOx_xzGjhtcs4DkJVW-r0hQUEL5fsNAI205nUXfuuk0IeFxP0mV3n98t6HxcQDGSmNuxmXHLOKAajQBk-6oCLOxKQwSXojyoHdp7LK4LjH5P7fnqzWMDFj7frzCc9SkoveebZJsK97C0hXOd7Ln83fNcFFRWDzDHrYRuqNaPBngHu9JO7InoliE.uoHJkYLIKyEGD5IaU4STL0TdiZzjubODXCY7HtlVxI8&dib_tag=se&hvadid=83288363786574&hvbmt=bp&hvdev=c&hvlocphy=88716&hvnetw=o&hvqmt=p&hvtargid=kwd-83288404367763:loc-190&hydadcr=12564_13429831&keywords=bobbin+winders&mcid=bd4090e3780335ea8cc48259bce3276a&msclkid=33e3edd2dc3d1304abb6840e821f34da&qid=1776049700&sr=8-8
Hola Bryan
Esa podría ser la conclusión a la que llegue finalmente. Mientras tanto, voy a probar todo lo que me han recomendado hasta ahora. Incluso pienso comprar el conocido hilo Gütermann para descartar que el problema esté relacionado con el material en sí, aunque sospecho que no será así.
Si ninguno de estos enfoques resuelve el problema, probablemente me alejaré del método de Domanov y evitaré invertir más tiempo o recursos en él.
Simplemente cogeré esa máquina y la tiraré desde mi balcón a la piscina.
Atentamente
Jacobo
Buenos dias Jacek, me alegra verte por estos lares, como ya te dije yo no tengo esa maquina, preferí hacerme la mía propia, así si salia mal solo podía cabrearme conmigo mismo, jejeje, ya he leído las soluciones que te están dando, y creo coincidir con todas, también he comprobado que es más complicada de lo que en inicio podía pensar, las tensiones de los carretes alimentadores es super importante, y por lo que veo, no es fácil, como comprobar que los 3, 4 carretes tienen la misma en la maquina, si esa presión se realiza con una palomilla, tuerca, complicado...he de decir también, que en la mia, al colocar los hilos, filásticas, los tres hilos que componen el futuro cabo, deben de tener la misma tensión en 5 m, cosa muy complicada, pero al ser en tanta longuitud es menos apreciable. Un saludo amigo, desde España, y virutas:pag
Bob don't worry, my friend—it's absolutely no problem at all. I know that on these forums we can find a lot of interesting things, as well as plenty of experts. Even if some people are just here to learn without sharing their own ideas and experiences—well, there's a place for everyone!
To be honest, I handle the mechanical and design aspects just fine, but when it comes to electronics—that's where I'm completely lost! Haha. However, if I have a small schematic to work from then boooom!. I can really buckle down and figure it out.
Thanks again. As always, I truly appreciate people like you who share their knowledge and experience with the community. I'm already taking notes and getting ready to dive in and start studying this astronomical device!! ROTF ROTF
Also, thanks for the link to the coil winder and for the YouTube video.
That’s what these forums are all about!! I really appreciate it.
Kind regards
JC
Así mismo como lo dices, no veo la forma humana de que las 3 bobinas están enrolladas con la misma presión, por ahi un colega me envió una maquina para enrollar esas dichosas bobinas, que mientras no hagas un cabo de 1mm creo que pueda sacar mas de 2m de soga, pero la cosa se complica al ampliar la cantidad de hilos por sedal, en fin un rollaso tio!! Hare mis pruebas con los datos que nuestros colegas me han pasado pero ya como que no descarto la posibilidad de tirar esa maquina a la basura y hacerme la mía, que como bien dices si queda mal solo sera culpa mía jajajajja ROTF ROTF Un cordial abrazo hermano!! y virutas de vuelta!!! por cierto ponte mascarilla con tanta virutasROTFROTFROTFROTF
Kind regards
JC
Your best to purchase a 2nd hand sewing machine and use that to wind the bobbins with threads.
That singer winder does not wind the threads in tight enough. I purchased one and I taken it back to the store.
You can buy a 2nd hand sewing machine cheaper than that singer winder.
Interesting. I haven't encountered that problem, although my stand-alone bobbin winder isn't a Singer model. I found that there wasn't any problem regulating the tension using the tension adjustment knob. Perhaps the problem is that the tension setting device doesn't work as well with thicker thread because it takes more power to pull a thicker thread through the tensioning gizmo?
That’s the exact problem Bob, I’ve run into when trying to make a rope about .8mm-1mm thick: with those spools, the tension becomes absolute garbage, not to mention that you'll be able to do about 1.5 m only.
For now, with all the tips you've given me, I'm continuing to experiment with cheaper thread until my Gutermann spools arrive.
Regards
Regards
I think you'll find that thread is a lot less expensive per foot when purchased online from WAWAK in larger spools.
Believe me, Bob, I checked in Amazon and WAWAK. They only had black available in large rolls; for other colors, they only stock 3,200-yard spools for $45.
Then I looked at Ropes of Scale, based in Canada. They carry the three basic colors in fact, those are the only three they sell: black, brown, and beige (or khaki). Their rolls come in 10,000-meter lengths. I decided to go with them because I noticed that most modelers use that particular thread, and it works well for everyone. I pay for 3 colors 10,000 m spools $79 including taxes and shipping
For now, I’m using a spool I got from Amazon just for experimentation purposes. I also noticed that it has quite a bit of sheen. Anyway, thanks for the recommendation, I really appreciate it.
regards
Here in Australia we can not buy rope of this quality unless we purchase from overseas, which increases the cost considerably.
I’m contemplating on selling rope to help cover the cost of what I’ve spent of late on this rope making task. Especially here in Australia.
I hope you guys don’t mind. If I do that. Thought I should check here first.
I'll bet you'd find a market for it without any problem if Australia is anything like every place else.
Oh! Wait! I forgot about the coriolus effect. Does right-hand-laid rope curl to the left Down Under? :D
