Modelship Dockyard - New Kit [Modelship Dockyard] PoF H.M.S. Enterprize 1774, the 1/48 version!
The design of the mast has been fully completed, but no one has yet made an order application to us. Therefore, it has not been listed yet
Thanks.
On another note, I have reached out now 2-3 times regarding availability of Firiezes for the hull without response from Victor who did indicate they would be offered.
Any update would be appreciated.
Tim
Cannot tell exactly from your picture but it appears you've closed gap at bottom of hawse pieces, the air gap remains constant right to frames.
If I understand correctly, your ? about inside hawse angle is resolved by simply laying on the jig and tapering hawse until it follows flow of jig....final sanding when fitted.
As far as deck beams.....ends butt against sides of keel, On lower deck not super critical since deck beams, lower beam ends, carlings are mostly covered up with waterway planks found, as Victor pointer out, on G4
Beam placements easily ID'd by taking close look at PDF, shows port location and which frame on port to locate ends of platforms.....pretty straight forward.
This method I used and everything measured out.....biggest risk is if wrong, compartments will obstruct knees, hanging knees.....following what I described I had zero interference on any.
Do be aware the sheets for all compartment walls are general, not exact, you need to make "modelers judgement" as to exact height, length to fit under beams and between knees. Their EXACT measurement not critical.....just insure all fit.
P.S. when fitting up inside beams, I'd highly recommend only using 3-4 jigs at a time, mark beams with light pencil, then use medium CA, very lightly......will bond in 10 seconds or so, and follow right from bow to transom.
I can tell you, using this methodology all my deck beams came out dead level the entire deck.
This was a major concern because never used this system but it worked out very well.......never required any measurement from plan with height gauge.
Knees require fair bit of adjustment to follow flow/taper of frames.....be advised.
Tim
love the frame round the stern chaser Bit later now as ive fixed all the Knees they are OK(ish)
Is this the HMS Surprise/Unité kit they show coming out soon? I hope the photo on their website is not supposed to be the Surprise.
Thats the one
Its the guy who designed the Caldercraft and Amati Victory
Looking at his other models it will be really good
A coolegue does a FULL build wih instructions better than DE LOngli and hopefully as good as he best Amati
He manufactures then in the UK most if the work hw has a workshop where is manufactured
Never bought a kit from there
I amnow having to admit I just cant build models lke i used too
