If we get any response, it will probably be "They are working on it".
Why? You will be busy with current offering for a couple yearsI second this!! Been anxiously awaiting the rigging set before jumping in on this kit
Thanks.The design of the mast has been fully completed, but no one has yet made an order application to us. Therefore, it has not been listed yet
Because I want a fully rigged model, I’m not going to waste money buying it only for the rigging section to never be released.Why? You will be busy with current offering for a couple years
love the frame round the stern chaser Bit later now as ive fixed all the Knees they are OK(ish)Cannot tell exactly from your picture but it appears you've closed gap at bottom of hawse pieces, the air gap remains constant right to frames.
If I understand correctly, your ? about inside hawse angle is resolved by simply laying on the jig and tapering hawse until it follows flow of jig....final sanding when fitted.
As far as deck beams.....ends butt against sides of keel, On lower deck not super critical since deck beams, lower beam ends, carlings are mostly covered up with waterway planks found, as Victor pointer out, on G4
Beam placements easily ID'd by taking close look at PDF, shows port location and which frame on port to locate ends of platforms.....pretty straight forward.
This method I used and everything measured out.....biggest risk is if wrong, compartments will obstruct knees, hanging knees.....following what I described I had zero interference on any.
Do be aware the sheets for all compartment walls are general, not exact, you need to make "modelers judgement" as to exact height, length to fit under beams and between knees. Their EXACT measurement not critical.....just insure all fit.
P.S. when fitting up inside beams, I'd highly recommend only using 3-4 jigs at a time, mark beams with light pencil, then use medium CA, very lightly......will bond in 10 seconds or so, and follow right from bow to transom.
I can tell you, using this methodology all my deck beams came out dead level the entire deck.
This was a major concern because never used this system but it worked out very well.......never required any measurement from plan with height gauge.
Knees require fair bit of adjustment to follow flow/taper of frames.....be advised.
Tim
have you looked at the New Model due any time from Vangaurd Models Not Rigged but fully enclosedBecause I want a fully rigged model, I’m not going to waste money buying it only for the rigging section to never be released.
Thats the oneIs this the HMS Surprise/Unité kit they show coming out soon? I hope the photo on their website is not supposed to be the Surprise.
Maybe their kits are supposed to be the converted merchant and they both just misspelled the name on the kit.Mamoli's and Artesana's
Totally agree with you, but the drawings are definitely two different ships. The question to me is whether the kit is the Surprise 1774 or the Surprise/Unite. The kit looks more like the Surprize 1774 than Unite to me and from what I could find, the kit is supposed to be the Surprise 1796. There was a build log of this proposed kit at MSW but no way to find it now.Allan,back than grammatically both version was correct ,you could write either way
It is the Unite version and is based off those plans. I believe Chis is including two figurehead options so people can go with the historically accurate one or the movie one depending on their desires.Totally agree with you, but the drawings are definitely two different ships. The question to me is whether the kit is the Surprise 1774 or the Surprise/Unite. The kit looks more like the Surprize 1774 than Unite to me and from what I could find, the kit is supposed to be the Surprise 1796. There was a build log of this proposed kit at MSW but no way to find it now.
Apologies Zoly and everyone. Totally understood and embarrassed.Ok guys ,this thread is about the Enterprise from MD and we are discussing another kit from another manufacturer,please keep the discussion about the Enterprise
