I study this indeed. I looked into Steel, Anderson, Lees, Yk, Witsen and blunt. Because I also was interested in the subject. What I found was that it where not big ropes, they didn't have to carry a lot of weight (the sailers in that time doesn't look like me) and a small rope will be keep better in place on a big shroud line. This is wat I found:
Ratlines are in most cases made of 1.5-inch circumference rope (See Lees and Steel). The diameter would be a little less then a half inch. This was for almost every yard in history common use. Ratlines on scale 1/50 to 1/75 will be somewhere between 0,2 and 0,15 mm. in diameter.
On the model it will look better to go for the smallest rope you can find. So 0,15 looks better then 0,2
The distance between ratlines is between 13 and 15 inch (same Lees and Steel). In cm. between 33 and 38 cm. on scale 1/50 to 1/75 between ~7-4 mm.
I hope this answer helps in this case.
Thanks for the quick reply, Stephan.
The question related more to the 'international nautical' designation of rope measurements in circumference. Which can cause confusion if the diameter is 'sometimes' mentioned. Do they also refer to 'circumference' in the old Dutch documents?
In Yk, for example, he sometimes refers to the circumference and sometimes to the diameter. He also mentions the thickness around the round or the thickness at the cross, referring to the circumference in the first case and the diameter in the second.
Screenshot 2026-04-20 at 11-23-28 De nederlandsche scheeps-bouw-konst open gestelt vertoonende...png
Witsen is talking about the thickness around (circumference) when he mentioning rope thickness
Thanks, Stephan. In any case, it is clear that they not only state the size number but also whether it is circumference or diameter.
Thank you Peter and Stephan. I guess there is no real standard way of specifying line. If it is not explicitly spelled out as cir or dia in the text, you just have to use your common sense and realize that they would never use, for example, 1.5" diameter line for ratlines. ROTF
As a side note, the photo that Stephan posted above has answered some questions I had about ratlines - thank you Stephan. I had always wondered what was done with the free end of the ratline at the outermost shroud and how they kept the inner clove hitches from sliding down the shroud with the weight of the sailor. I see from the photo that the free ends are pulled up and seized to the shroud and that there are seizings on each innermost shroud just below the hitch to keep it from sliding. So, for those of you who REALLY want to model to true scale ... ROTF
Now you gonna hate me :)
The first picture was the Dutch method, and above picture the English and French method with an eye on the end of the ratline.
And on the Bluenose and Balder they used the same methode as Stephan posted above:
The drawing is about the Bluenose and the insert picture is from the Balder.
It's depending of the scale you are building is this is possible to make.
But Johann @archjofo showed it here in --> this post of his build of La Créole in1:48. <--
Eye-splicing 0,15mm line? Piece of cake! ;) The hard part will be finding the correct scale size for the small stuff used to lash the splice to the shroud! ROTF
Seriously Stephan, thanks for posting these - and thanks Peter for indulging us on your log.
The starboard side done as well:
That took a bit more time. It does need to be at the same height and alignment as the port side.
Total picture so far:
The starboard rigging is not yet divisible. When attaching the ratlines and spreader bars, I am going to integrate the small magnets. At least ..... that is the idea.;)
She’s coming along pretty fine. And I don’t think everybody appreciates how small the model actually is. From all te details I’d made a mind picture of something table sized. And was surprised when I saw her ‘live’ in Amsterdam.
I agree. How Peter manages such fine detail at this scale is legendary. Cheers Grant
Thanks for the compliment, Marco and Grant. But ........Size and dimensions are actually very relative.;)
A critically positive member of the Dutch forum found the distance between the deadeyes on my model quite large. When looking at the drawings and on the Balder itself, I also found the distance to be large. But that is the case with many sailing loggers.
Both shrouds on the Balder:
The distance between the deadeyes is 75 cm / 2.5". That is 15 mm / 0,59" on my model:
They will be positioned slightly closer together once they are tensioned with the lanyards.
Let me mention two points of interest that you can see on the pictures of the Balder:
1: The large amount of line looped in long loops along the lanyards. I can understand that for the main mast, because when lowering the mast while fishing, the lanyards must be released. For the mizzen mast, I do not understand it (yet). That simply remains fixed in place. I asked various 'experts' but have not yet received a satisfactory answer. Perhaps to have enough length when tensioning the lanyards by hand.
2: The ratlines lines that have also been fitted between the lanyards. Quite handy, as became apparent last week when I had to climb up there. Then that 75 cm (and the section below) is quite a big step. At the mizzenmast, those ratlines are no problem because that stays standing. But again the mainmast. When it is lowered, the halyards are released by the deadeyes. Then those ratlines have to be taken off. And on the real fishing vessel ..... every time e when fishing .... again and again ....... I suppose the current crew members will say: "We never lower the mast. If we have to, we'll just untie them.";)
Last week, on the original Balder in beautiful weather, I sanded the 'kluis’ and applied primer. Little by little, it is becoming presentable again.
No update on my Balder for a while, as I am away for another week on my bike with former colleagues. Heading to Germany. Today, first part of the Moselle and then across the Rhine on a ferry.
Still 4 days to go.
Back home, I found 2 types of black lines in my post: the 0.25 mm from Ropes-of-Scale @Ben and the 0.20 mm from Stephan @Steef66.
I set to work with these to make the ratlines in the original way: with spliced eyes on both sides of the outer shrouds and the clove hitch around the middle one.
Thanks to photos by Johann @archjofo, I first prepared a small needle of a syringe. To make an ‘fake’ eye splice, you prick the line so that you get an opening in the line:
That is the 1st step at the top left. You then insert the end of the line into the hollow of the needle. You then slide the pricked part off the needle and you have the 1st pull-through. Next, you prick the line again right behind the 1st one. Again, insert the end into the hollow and slide the line off again. Then you have 2 loops. I pull the eyelet with the splice onto a pin and give it a dab of glue. I then make the other eyelet at the correct length.
I made several attempts with the 0.20 mm line, but to hit the right spot in a line 4 times without a strand breaking... That is just over the limit. With the 0.25 mm line, it works.
What is the correct length? For the first two, the ratlines go around the folded shrouds. Then I need an extra 9 mm of length to tie the clove hitch around the middle one. The distance between the two outer shrouds is 17 mm. Then the two eyes had to be 26 mm apart. A matter of placing 2 pins at the right distance and working around them.
With this as the result:
On the Balder, the speaderbar is slightly higher, as are the 2 ratlines. I kept to the old drawing. Once the glue is completely dry, I might be able to shape them a bit more neatly.
With the first one, taking all the attempts, it took me a couple of hours. The second one went 'a bit' faster. Now I need to build up some dexterity and routine for the other weaving lines.
Back home, I found 2 types of black lines in the mail: the 0.25 mm from Ropes-of-Scale and the 0.20 mm from Stephan @Steef66.
Thanks to photos by Johann @archjofo, I first prepared a small needle of a syringe. To make an eye splice, you prick the line so that you get an opening in the line:
I made several attempts with the 0.20 mm line, but to hit the right spot in a weaving line 4 times without a strand breaking... That is just over the limit. With the 0.25 mm line, it works.
What is the correct length? For the first two, the weaving lines go around the folded shrouds. Then I need an extra 9 mm of length to tie the clove hitch around the middle one. The distance between the two outer shrouds is 17 mm. Then the two eyes had to be 26 mm apart. A matter of placing 2 pins at the right distance and working around them.
On the Balder, the speaderbar is slightly higher, as are the 2 weaving lines. I kept to the old drawing. Once the glue is completely dry, I might be able to shape them a bit more neatly.
Impressive. Of course the shrouds get closer as you go up - more art than science...
Hi Peter,
You did a fantastic job! When comparing the original to your model, there's hardly any difference.
I also had some trouble with the fake splice at first. But with time, it went quite quickly.
By the way, I saw it:
Bavarian motorcycles and Bavarian beer – those are excellent exports from my home region...
Best regards from Bavaria,
Johann
