I really liked how tight your inner hull planking is. I’m glad mine can’t be see. Those little hinges on all the doors are a pile of fun. I do like how they look however. Looking good.
Thanks JimI really liked how tight your inner hull planking is. I’m glad mine can’t be see. Those little hinges on all the doors are a pile of fun. I do like how they look however. Looking good.
Got the wire from Amazon. It is a little thicker, the AL wire is probably 32 gauge, but it strips easy using your thumb nail.Hi, great job. If I can afford some advice, to create the groove I used the cutter (I have a Proxxon M70), I work faster but above all more precise and clean. What 30 gauge wire is it? Purchased where? Thank you and good work
Good morning Tony. I had this problem too and I found the following solved it rather nicely.But unfortunately the blackening still dried with a chalky residue.
Hi, congratulations, you're doing a great job. I wanted to point out that, on the side where the structural pieces will be cut to leave only the gunwales, the strips won't be placed as shown in the photo of the work I'm doing.Video 15 - (Part 1)
Here I lay the lower gun deck and begin the inner planking (more on this later).
The underside gets one coat of white then a light sand and a second coat.
Top receives a light sand before one coat of stain.
I wanted to test fit the mastsn with the lower deck temporarly in place. But first I prepared the foot of the mast as per the mast instruction sheet. You need to create a 6mm cube. Simply job to chisel the profile.
I then got the depth correct and sanded a chamfer to aid the mast locating into the recess in the hold.
Perfect! Mmmmmm need to blow some of that dust out!
Ok lets get that deck down.
As expected the finger joints didn't want to play ball (as I expected). I once again turned to a technique I call tack gluing. I use this method a lot on my plastic models, especially large area such as the left and right sides of an aircraft fuselage. It basically entails getting only a part of the area to be glue correctly aligned. This is a lot easier than trying to glue the whole finger joint area in one go. Getting all the fingers to sit correctly is difficult.
Above, using a weight I managed to align the fingers near the weight. I made a mix of about 50% PVA to 50% water and ran a loaded brush over the area. Once I had cleaned off any excess and left it for about 30 mins, then I came back and repeated the process. This time I left the glue to set for a few hours. Yes it's slow process but the results are worth it.
More useful objects are used to manoeuvre the fingers.
I was happy with the fit when done.
In this image I have laid the first row of the inner planking, but I am going to stop right there. It has been noted by other modellers (AlanOES and Humble Ship Builder) that there is something not quite right in regard to the instructions. The instructions would have you continue the inner planking up to the next level ending planks flush with the gun port. The problem is when you fit the gun port linings they don't sit against the back of the planking which they should do. AlanOES has posted some excellent images highlighting the issue.
The up come of following the instructions is two fold. 1) It causes an issue drilling the holes for the cannon ropes and 2) You are expected (I think) to fill the area where the planking should be with filler. The guy in the video uses a mix od CA glue and talcum powder. This just looks like messy and an awful amount of hard work!
My solution is to fit the gun port linings first, then install the planking flush with lining.
Thanks for dropping by.
Tony
Tony
I'm sorry if I allowed myself to tell you thisYou are quite right, my mistake, I will pull that row off today. Thanks for the heads up to my error.
No, thanks for pointing it out to me. In fact I've just removed the strip without any real damage, just a bit of sanding to do on the ribs. Thank youI'm sorry if I allowed myself to tell you this
Yep it just takes time and patience.Columns look great. I remember I didn’t like making them but after getting a few done I figured out the best way for me and started making quality looking columns and fairly quickly.
Imagine, however we are at the same point of work, I follow you with pleasure and interestNo, thanks for pointing it out to me. In fact I've just removed the strip without any real damage, just a bit of sanding to do on the ribs. Thank you
You may be slightly ahead of me. Today I intend to start sanding the outer hull. Not sure how long this process will take.Imagine, however we are at the same point of work, I follow you with pleasure and interest
Already done, I'm starting to put the slatsYou may be slightly ahead of me. Today I intend to start sanding the outer hull. Not sure how long this process will take.
I regularly fitted the beak to check the plank end point, I wanted it to a snug fit.
