La Renommee 1744 1:48. (CAF) by Salty
Paul, I am very much looking forward to you restarting your La Renommee. It’s a super kit and I’m a little surprised there aren’t more examples of her on SoS.
Brad, yes, slowly does it. The instruction manual is like a box of chocolates - sometimes one picture can take a week, while other times it can take just a day.
I have been working on the mast steps and internal braces:
I’ve gone for Brass Black on the eye bolts and rings and quite like the effect!
I’ve also stained the wood with Danish oil. At first I didn’t like it because I thought the finish was too shiny. I think this was because the finish wasn’t smooth enough and I used too much oil. After sanding back with 600 grit sandpaper and reapplying the oil more sparingly, I think it looks better. I might leave the ceiling planking unpainted at this stage as I probably need to keep the inside as light as possible. A penny for your thoughts?
Finally, CAF kits constantly surprise me with their attention to detail. The mortises in the mast steps were cut at a slight angle so that the connecting pieces slope inward at the same angle as the chocks. The wonders of CAD and CNC never cease.
Kind regards
Salty
Beautiful Work!! Section 5 has arrived! I need to finish up the masting and rigging on OcCre Jabeque, and then I'll begin Section 5
Brad, I am using Rustins Danish oil, although Watco is also available in Australia. It’s the natural one with no stain, but it definitely brings out the colour of the wood. Thanks for the tip about gluing. The finish is a little tacky initially, but hardens nicely after a while.
Paul, great news. I must confess that I haven’t opened my kit, so thanks for your photos. I think I can see a few packets of cannons which will be a challenge for my fat fingers. Your Jabeque/Xebec is looking very nice as well.
The next few steps involve setting the position for the deck beams. Plywood templates are supplied to help. At this stage, the only the brackets for the lower deck beams are installed as there is still a lot of detail to be fitted underneath.
This is for the lower deck:
Sort of straight forward, at least by ship building standards. The beams are CNC cut, but the ends had to be beveled to fit the curve of the hull. Even with the plywood templates, the instructions say to check with the plan. Thankfully, it all looks right, although there’s very little room between the beams and the foremast.
On the ship, it must have been pretty cramped below, with only about five feet of headroom on the lower deck and even less when passing under a beam of the deck above.
The plan is to cut the frames away from just under the lower deck down to the top of the longitudinal ceiling planking.
Kind regards
Salty
Kind regards
Salty
Looking very nice!!
More deck beams, this time in the area immediately behind the foremast.
The beams for the lower deck are getting wider and are now made of two pieces scarfed together. This is what they look like when they come out of the billet:
In some beams, the scarf is not deep enough and the shoulder protrudes. I’ve decided to keep the shoulder the same height and adjust the depth. A little bit fiddly and no one will see it, but at least I know all the scarfs are the same.
Here they are in place with the scarfs fixed with their U shaped brackets:
And here is everything in place:
Even with the templates, it’s been tricky. It’s a tight fit getting the template in place and I had to keep checking it hadn’t slipped. In addition, the tops of the beams aren’t supposed to be parallel to the top of the ceiling planking as distance is greater in the bow and narrows as you go aft. I really struggled with this for a while as it didn’t seem natural, but the plans clearly show it. Despite all this, the beams seem level, although I think the port side is marginally - about 2 millimetres - higher.
Kind regards
Salty
Kind regards
Salty
yes, I remember all the "fun" I had with these as well! but yours look very good!!
Kind regards
Salty
Looking mighty fine Salty. Kudos. Don’t talk to me about deck beams…. ROTF . I redid mine a few times before that test spirit bubble finally decided to behave itself. Cheers Grant
