USS Constitution - Model Shipways
Thanks for posting. Many great ideas. Just starting masting on HM Badger, and my Constitution hull is waiting for hers.
Your work convinced me to pull the trigger on the Proxxon DB250.
Thanks again,
-Rich
Take a closer look at my more recent posts. I switched from Proxxon DB250 to the 17" metric version of the Sherline lathe. I caught it on sale and wish I'd invested in that instead of the Proxxon DB 250. If I weren't already giving the Proxxon lathe away to a friend just starting out (and on a very limited budget), I'd offer you mine. You still have to accessorize the stock Proxxon and you won't truly be satisfied with it. If XKen thought the Sherline was the lathe to have, that's good enough for me..
Hi, reviewing the log, see a few notes about my work. It’s an honor to be included.
I followed Bob Hunt’s practicum.
The deck planks are individual. Did not add additional support, worked with the kit bulkheads/beams. Idea was span four beams, with a butt joint every fourth row. However, see some planks that are much longer, can’t remember why that is. Also can’t remember why I didn’t level the deck.
The deck planks fore and aft are not tapered, just the planks going in amidships.
For the hull planking, lined out the belts, calculated the number of planks needed, used proportional dividers to mark the width on the plank at each bulkhead.
Thank you.
-Rich
I'm about to start the hull planking on my Constitution, Rich, and have seen several mentions of using a proportional divider to assist in the markings within each belt. So, I'm about to make another purchase...
And yes, I've already purchased the Proxxon DB250 (prior to Peter's Sherline revelation) but haven't even used it yet.
Hi guys,
Ok, now looking at the Sherline.
Ok, now looking at the Sherline. Why metric?
Ugh, now looking at a Sherline package Mill and Lathe. Instead of Sherline lathe and Proxxon mill.
The big idea is setting up to do masting quickly.
Recommendations? Compound slide is a necessity.
These are going to be some expensive spars ROTF.
The only difference between men and boys is the price of their toys. Been there. Done that.
Want to make a significant dent in the stash.
Raised cash by selling some kits and Powermatic 3520 lathe - turned a few main masts on that beast.
Time to take the shipbuilding to the next level, so far it’s been skill building. Now it’s time to get precise. Thanks men.
You can do quite nicely with the Proxxon mill. I looked very closely at the Sherline offering but decided that it wasn't a significant improvement over the Proxxon mill. That is not to say that I didn't seriously consider it anyway.
To answer the question about metric, when I started working with these very small dimensions, it was sooo much easier to use a metric rule then dealing with fractions - especially on planking the lower strakes on the hull. The proxxon mill was in metric, so I got simply got used to it.
Thank you, very helpful.
To answer the question about metric, when I started working with these very small dimensions, it was sooo much easier to use a metric rule then dealing with fractions...
I have mentioned that to numerous friends and family when they ask about my retirement's shipbuilding hobby... one thing that has stuck with me most is that I much prefer measuring and calculating in metric than imperial measurements and fractions.
I’m hip with metric, being a mech eng……
I forgot to mention, if you are shopping for the sherline lathe, give serious thought to the four jaw chuck. The three jaw Chuck won't work with square stock. The four jaw Chuck will work with square or round, but you need to be precise with your square stock. Being a Mech engineer, this should be no problem for you.
No worries, Grant.
I've had the same thought when perusing other posts reconstructed rrom the ashes of the MSW disaster.
I'm glad you find my build of Interest. Hope I don't disappoint going forward.
Does anyone have thoughts on whether or not to include studding sail yards on the Constitution?
I'm pretty sure most builders will be including the studding sail booms, but I don't think I've ever seen anyone install the matching yards.
It seems to me these should be installed in pairs - one boom to one yard. Given the incredibly small diameters in the plans for the studding sail yards, I'm reluctant to even try to make them.
In the real world, where would the studding sail yards have been stored when not in use? Simply last to their respective yards and royals?
Thoughts anyone?
P.S. to ERSRich
You probably don't need the 17-in lathe either. I have found that for longer lengths of narrow stock, the center tends to bow while turning. I still have to resort to using sandpaper on long thin planks. The 8-in lathe would probably serve you well, unless you have other uses for it.
PM 3520 is a BIG lathe for small spars and masts, I have small Jet 1220 for pen turning and for ships it is still oversized.
