Impressive!
Take a closer look at my more recent posts. I switched from Proxxon DB250 to the 17" metric version of the Sherline lathe. I caught it on sale and wish I'd invested in that instead of the Proxxon DB 250. If I weren't already giving the Proxxon lathe away to a friend just starting out (and on a very limited budget), I'd offer you mine. You still have to accessorize the stock Proxxon and you won't truly be satisfied with it. If XKen thought the Sherline was the lathe to have, that's good enough for me..Your work convinced me to pull the trigger on the Proxxon DB250.
For the hull planking, lined out the belts, calculated the number of planks needed, used proportional dividers to mark the width on the plank at each bulkhead.
Ok, now looking at the Sherline. Why metric?Take a closer look at my more recent posts. I switched from Proxxon DB250 to the 17" metric version of the Sherline lathe. I caught it on sale and wish I'd invested in that instead of the Proxxon DB 250. If I weren't already giving the Proxxon lathe away to a friend just starting out (and on a very limited budget), I'd offer you mine. You still have to accessorize the stock Proxxon and you won't truly be satisfied with it. If XKen thought the Sherline was the lathe to have, that's good enough for me..
These are going to be some expensive sparsnow looking at a Sherline package Mill and Lathe. Instead of Sherline lathe and Proxxon mill.
.Want to make a significant dent in the stash.These are going to be some expensive spars.
The only difference between men and boys is the price of their toys. Been there. Done that.
Thank you, very helpful.You can do quite nicely with the Proxxon mill. I looked very closely at the Sherline offering but decided that it wasn't a significant improvement over the Proxxon mill. That is not to say that I didn't seriously consider it anyway.
To answer the question about metric, when I started working with these very small dimensions, it was sooo much easier to use a metric rule then dealing with fractions - especially on planking the lower strakes on the hull. The proxxon mill was in metric, so I got simply got used to it.
I have mentioned that to numerous friends and family when they ask about my retirement's shipbuilding hobby... one thing that has stuck with me most is that I much prefer measuring and calculating in metric than imperial measurements and fractions.To answer the question about metric, when I started working with these very small dimensions, it was sooo much easier to use a metric rule then dealing with fractions...
I’m hip with metric, being a mech eng……I have mentioned that to numerous friends and family when they ask about my retirement's shipbuilding hobby... one thing that has stuck with me most is that I much prefer measuring and calculating in metric than imperial measurements and fractions.
I forgot to mention, if you are shopping for the sherline lathe, give serious thought to the four jaw chuck. The three jaw Chuck won't work with square stock. The four jaw Chuck will work with square or round, but you need to be precise with your square stock. Being a Mech engineer, this should be no problem for you.I’m hip with metric, being a mech eng……
PM 3520 is a BIG lathe for small spars and masts, I have small Jet 1220 for pen turning and for ships it is still oversized.Want to make a significant dent in the stash.
Raised cash by selling some kits and Powermatic 3520 lathe - turned a few main masts on that beast.
Time to take the shipbuilding to the next level, so far it’s been skill building. Now it’s time to get precise. Thanks men.
