Bluenose I - YuanQuin 1:72 - Loracs (in progress)
Unusual problem - Walls Warping: I came across an issue that is puzzling me. I can't really find a solution and/or a prevention. Maybe someone here has a tip. The issue is the following:
I have been edge-gluing strips to create walls (see above). I then place the wall between two pieces of wood and let it dry either overnight or up to 3 days. When I free the wall, everything is fine for several hours, then I see warping that gets worse with time (see below in picture). Would treating with linseed oil right after the overnight dry help prevent that? Any way other trick? Have any of you ever seen this issue?
I'm guessing that the one solution would be to build the wall frame and glue strips only to the frame - avoiding edge gluing all together.
Hi Loracs. At first I haven’t gave you post a ‘like’ ……. ;) ….. because you don't want this to happen. But at the end I did, you showed us one of the pro’s and con’s of scratch building
Hold it in some steam for a while, then hold it against a surface with a slight opposite curve, and let it cool again. You'll have to experiment with the amount of time. It also depends on the glue you used. PVA softens slightly and will regain its bond as it cools.
You are right though... posting issues encountered can be valuable to other builders. I have no problem with that since, for the most part, I'm still learning. I did try steaming and re-forming.... but after a while it will curve again in a hot day. You can see that I'm dealing with this issue for more than a week, with few experimentations. In addition, this happens reproducibly on all 3 versions.
My assumption is the following: when I edge-glue, there is some glue than spread in the opposite side facing the gluing bench (cover with a plastic sheet). This is un-avoidable. The upper side does not since you tend to see it and wipe right away. Furthermore, it does not spread but just "bead" slightly at the strip's edge. After the glue set, you end up with a side that is permeated with glue and the other side free. Sanding afterward just removes the surface glue but not the permeated portion. Air humidity must then expand wood from the upper side but not has much the lower, creating a gradient that deform the overall structure.
Hello Loracs, I don't know if this will help you...but it appears as if you have added trim details to only one side of the bulkhead. In my experience, when working with thin flat surfaces, whatever you do on one side you must also do on the other side (this applies especially to larger structures - less so with smaller things like shot lockers or wells). This might even mean needing to sand down each respective surface to make the structure thinner to avoid ending up with something too bulky.
IMG_1115.JPG Front
IMG_1117.JPG Back
IMG_1118.JPG Front
IMG_1121.JPG Back
I hope this helps.
View attachment 582990 Front
View attachment 582991 Back
View attachment 582992 Front
View attachment 582993 Back
I hope this helps.
That reminds me that I also put the wall covering on both sides of the frame.
Thanks all for the inputs... the build is slowing down to a crawl - back pain. Just need a small break until it goes away. In the men time, I have a standing desk on its way from upLift (expensive but look quite nice). That should help too since 90% time is either building or on the computer.
Greeting all, I can finally get around building the magnificent Bluenose. This will be a first for me in many areas. First, POF kit with focus on the ribs and internal structures. Second, as partial build of the more detailed cabin and Fish-hold. You get it Peter Voogt' log will be a great inspiration. If I can achieve 1/2 of what (and many others) have done, I will be happy. Lastly, I still thinking on how to modify the kit to display those details. Still don't really know what I will do... but one thing first: get the build going.
Let me first start with an introduction.
I don't know in many already have discovered it but there is a virtual tour of the Bluenose II available online. You can visit and virtually walk around above and below deck, as well as the wharf area. Nice to have... here the link
Bluenose II virtual tour
Lastly the Bluenose II by LB Jenson (1994). I have seen it referred quite a few times. It was a little bit difficult to find in the US... but a used book is underway (still in transit).
I for one am loving to see another builder start a copy of this model. I will gladly join your group. I loved.building this model so much I want to do it again.
Happy modelling
Back wall and captain cabin floor: My back issue is still ongoing.... this delay my update significantly. Slowly recovering... too slow to my taste.
Finally got the wall to stay straight... just kept it under two piece of wood for few days, with gentle heating with my heat gun few times. That allow the glue to be a little flexible while it set.
The second minor challenge was: how do I glue it in place. No support really in this area. So I added small side strip at the bottom. This and the final glue to the upper deck frame show hold it in place. Once done, I could set the captain cabin floor in place.
May take a while but will keep building. Just far more slowly.
View attachment 602991View attachment 602992View attachment 602993View attachment 602994
Nice to see you are starting up again. Small progress is still progress. Hopefully your back stays well and you can go on.
View attachment 602997View attachment 602998View attachment 603033
Good morning. Best of luck with your back. This is some wonderful work. Looking great. Cheers Grant
Lights - Lantern: Down the road I would like to add small LED lights to the build. The bluenose used mostly lanterns for on board lightning and navigation. The easy path would be to buy Photo-etched lanterns... but could not find any. I came across this simple solution. I'm posting it now because it will get lost and maybe of general interest here.
Fantastic idea & video, I am looking for ideas like this for my next build. Thanks for sharing.
Galley: I started to deal with the galley. Basically, two walls and a counter to prepare foods. The back area, accessible by the side door is likely were fresh foods, grains, flour, etc. was stored. The first picture shows a schematic view of the area. Later, a ladder will be built beside the counter. The counter is a little shorter than on the picture, but I was afraid that a longer one would interfere with the ladder (creative license?).
The second picture illustrates how I stabilize the walls and, later, glue then to the ship. The little planks seen odd now but will appear part of the wall once set.
Last picture shows both wall and the counter.
Bunkbed and table: the kit was not really designed to accommodate the sleeping area and the table. The floor, as designed, is just too high. In addition, all my materials are at 1mm thickness or 3 inch thick at scale... a little too much for furniture. Rather than trying to fit something that may just look odd at the end, I decided to leave the area clear of furniture and leave it to people imagination to think about what the sleeping/dining quarter may look like.
Note (2 days later): Looking back, I'm likely to add a sitting table and a little oven to fill the space a little. Maybe, I could set-up few hammocks for sleeping!
Its looking very nice, Loracs.
In the YQ-BN Group Build, we had AL-FI looking over our shoulders: Artistic License & Free Interpretation.
No plans and pictures of the inside of the original, so (almost) outcome is OK!
Indeed... I like that option and the flexibility to think of upgrade. Very satisfying build... I really like it a lot! Never do I have a boring day.
Support deck: I have been thinking for a while about a way to present, make more visible, the internal structure of the bluenose. I have seen numerous approaches here... each quite good. The most radical and courageous is obviously the split bluenose of
Peter. Here what I'm thinking, still experimental but viable: a semi-transparent upper deck.
I still like wood, so this will be applied in selected area to keep thing simple. I'm still planning to use the kit beams for the complex area that requires addition of transversal beams but elsewhere... transparent acrylic square rods, cut and shape as replacement. Here what it looks like as a first prototype.
a. cut to length using a small Japanese saw.
b: shape using the current beam as template using heat gun.
c. dry test: as you can see in the last picture the transparency is quite good.
Transparent beam: The kit deck beams are 4mm wide by 3mm depth. However, you can only purchase square acrylic rods. Now, decision... should I use 3mm (smaller in width than the wood beams but require no adjustment in depth) or go with 4mm rods and shave 1mm in a small area in contact with the side support (look easier to shave the wood side support). I'm edging toward the later, even if more work. The reason is that the ship will be seen primary from the top and, thus it may look slightly better.
Will be doing more testing with an area of 3-4 consecutive acrylic beams, both at 3mm and shaved 4mm. Dry testing should help make the final call.
