NORSKE LOVE - Billing Boats 1:75 scale
Well life and other interests have kept me away from the ship. So I decided to do something on the list at the stern. There is a crown up top center. So I modeled one and created a file to print. And I printed it…
This is why I didn’t try to carve it, about the size of a pea!
Then I painted and dry brushed it.
View attachment 610426View attachment 610427
And on the ship. That was way more time and effort than you can imagine just to add one tiny element. But then again, since ya’ll build ships too, you can relate! ROTF
Good morning Dean. It is a pleasure to see your NL again....even if it just the "rear end" ROTF. Your 3D printing design is pretty good (way better than mine. I'm trying to get AI to design for me but this is too a learning curve. I want to download a pic and it must make it for meROTF) - cool looking crown. Cheers Grant
That’s true.
That's some impressive CAD work, Dean!
Thanks Grant. I had to model it in Cad first referencing a picture. Then I had to export a STL file. Import that into Chitubox slicer software and create a print file with supports. Then print it, clean it and cure it. And finally paint it. But it came out nice, so worth it. ;)
Thanks Paul.
Quick update:
I decided to build the rudder and hinges and attach the rudder and stop chains before I do any further work on the stern.
My first attempt using the provided hinges…
It seems I’m a little rusty at wood working and dealing with tiny fabrication. The provided hinges should probably have at least 3 bolt heads. So I will change that.
On the ship…
When holding it up to the ship the pin location is too far away from the rudder in my opinion. This will result in too big of a gap. So back to the drawing board, so they say. I will have to change these to have a pin location close to the rudder.
See you when I’ve adjusted this and have it mounted! ;)
Quick update:
On the ship…
A I learned the hard way to do the rudder towards the end of the build. It was too easy to accidentally bang into it.
Quick update:
On the ship…
After the hinge redo, the rudder was mounted, painted and the stop chains added..
The resulting gap looks reasonable, and as close as possible without notches…
Next I need to finish the figure on the other side of the lower gallery and add the openings for the rear cannons on the stern. And of course there are many carvings still to be added. I may switch to doing cannons for a while so I can start doing deck furnishings. So much to do that I don’t know what to work on next.
View attachment 620307View attachment 620308View attachment 620309
Gorgeous ship!
Nice work!
The rudder with your new hinges looks very nice, Dean. Much better then the first ones.
