Wow. I'm amazed what you managed to achieve.Generating a figurehead is fairly easy job with ai, but you also fit it to actual piece of ship that looks historically accurate not some mumbo jumbo ai slop. Did you use a reference picture and asked to replace swan figurehead or some other method?
I could model your figurehead in 3d, it looks like a fun model to make
Take a look at diffrent brigs. Some of them also had a fancy stern ornaments
Thank you. I was shocked myself that the AI produced a result that completely satisfied me on the first try. I responded in more detail in a private message. Thanks for the link. I saw something interesting.
That figuerehead is absolutely stunning. No wonder one decides what's next just starting from this beauty female representaion. So... congrats even in large advance!
Judging by the fact that several people have contacted me via private message,
I've decided to explain in more detail how I generate figureheads in Gemini.
1. You should have a photo of the finished model you want to make, or something very similar. Preferably from a diagonal angle. Let's take the photo I generated (I used exactly the same one for my version, except it had a Cyclops figurehead).
2. In the AI task, you need to specify that it should not change anything (neither the model, nor the background, nor the tone) and simply replace the figurehead.
3. Ideally, you should upload the model drawings without the figurehead and specify that it take into account the position of the parts, rigging, bowsprit, and stem.
4. Add a reference image of the figurehead you want, or verbally explain what you want to see. If the reference image contains something you want to change, it's best to do it in a second pass. So, first let the AI insert the new figure into the model, and then you can change what you'd like in the reference. If you're describing what you want to see from scratch, be very detailed. What's the pose, where is the right hand, where is the left, where are the legs, what are they holding, what is the clothing, etc. If something's wrong, make adjustments.
I'll use another brig model being built by @Kortes as an example to show how I did this. Sasha sent me a couple of photos. In one, the girl is resting her hands on the ground and has a mermaid tail, but since that doesn't quite fit the name Le Favori, I made the legs normal. Sasha also sent a bust of a Greek warrior, and here it perfectly matches the abstract, masculine name of the ship. I wrote for the AI to add a body in Greek attire, a shield with a coat of arms, which fits the theme of good luck. Since the sword in the hand is too long, I wrote for the warrior to lead the way, with the sword in its sheath. Here are two options:
I think the second option with the warrior would fit right in with the title of "Favorite." Саша, как говорится - на здоровье
Hi, unfortunately AI can't do exactly what Gemini can yet, but I'm sure it should be able to do something, but how good it will look is the question...
This is the result from the link provided by Dubz Modeling World. A quick test of what AI can do. Added a photo and got the result. To get a better result you need to communicate more with AI
You can try to extract ai generated figurehead and put it into meshy. You can even sucssed in first try, but the best results are form multi reference wiews
Personally I wouldn't use ai, to me it's like using thermomix blender instead baking cake with own hands. As they say, to each his own. Nevertheless, I don't believe you can create sculptures by relying solely on AI. A middleman is needed to fit the results into the project as a whole. But it won't take long—maybe a year or two.
The upside is that AI can't cut wood(Yet)
Viele werden verstehen, dass man irgendwann anfängt, sich zu fragen, was man als Nächstes bauen möchte (und viele lassen sich so sehr mitreißen, dass sie ihre aktuellen Projekte gar nicht erst beenden). Natürlich werde ich kein neues Projekt beginnen, bevor ich mein jetziges abgeschlossen habe, aber ich kann dem Träumen trotzdem nicht widerstehen.
Ich besitze seit vielen Jahren eine Monografie über die Brigg Le Cygne 1806. Ich mag dieses Schiff sehr und wollte schon lange eines bauen, sogar vor Victory und Alert. Hier ist übrigens eine visuelle Darstellung des Größenunterschieds zwischen einem Kutter und einer Brigg im Maßstab 1:48. Der Größenunterschied ist nicht so groß, aber die Brigg ist deutlich größer.
Ich mag auch große Dreimaster, aber die Größe … Sie sind schwer im kleinen Maßstab (1:100) zu bauen, wie ich bei der Victory erfahren musste, und im Maßstab 1:48 sind sie so riesig, dass man nicht durch eine Tür passen würde. Ich wollte etwas im Maßstab 1:48 bauen, und der Kutter war die perfekte Lösung. Aber ich wollte immer etwas dazwischen. Es sollte klein sein, nicht riesig, aber auch eine komplexe Konstruktion haben, sowohl im Rumpf als auch in der Takelage. Und die Brigg Le Cygne war der perfekte Kandidat, aber!
Zwei Dinge haben mich die ganze Zeit abgehalten… Erstens die Karronaden. Ich mochte sie bis vor Kurzem nicht, aber! Ich habe mich mit dem Thema auseinandergesetzt, ihre Geschichte kennengelernt, die Mechanik und alle Vorteile gründlich studiert… und jetzt gefallen sie mir richtig gut. Zweitens die Ente… Die Galionsfigur der Schwanen ist einfach nur enttäuschend. Also habe ich angefangen, Monografien zu durchforsten. Es stellte sich heraus, dass die Franzosen etwa 60 Brigg-Schiffe ähnlich diesem gebaut haben, 20 davon waren exakte Kopien.
Also beschloss ich herauszufinden, welches meiner Schwesterschiffe die gewünschte Galionsfigur aufnehmen konnte. Es musste eine Brigg mit weiblichem Namen sein, die Karronaden mitführte (einige hatten entweder voll bewaffnete oder teilweise montierte Kanonen). Mithilfe künstlicher Intelligenz entschieden wir uns für die Le Faune 1805. Diese Brigg konnte eine weibliche Galionsfigur, eine Nymphe, tragen, also beschloss ich, in Gemini meine Vision der idealen Galionsfigur für diese Brigg zu generieren. Ich gab Zeichnungen des Bugbereichs ohne Galionsfigur und ein Foto eines Brigg-Modells mit einer anderen Galionsfigur, sodass Gemini nur das Modell nehmen und eine weibliche Galionsfigur einfügen sollte, die ich in Worten beschrieb. Ich beschrieb sehr detailliert, wie sie aussah, ihre Pose, wo sich ihre Arme und Beine befanden, wohin sie blickte, und fügte ein paar Zweige und Blätter hinzu, da sie eine Waldnymphe war ... und ich war einfach überwältigt vom Ergebnis!!! Hier ist, was ich bekam:
Ehrlich gesagt hatte ich nicht die geringste Hoffnung, dass es funktionieren würde, aber das war genau das Ergebnis, das ich mir gewünscht hatte... Ich habe absolut nichts geändert und mir wurde klar: Wenn man genau beschreibt, was man will, vollbringt Gemini Wunder.
Die Idee, die Galionsfigur zu ersetzen, wurde indirekt von @Kortes inspiriert, der nach diesen Plänen eine ähnliche Brigg baut, die er Le Favori nennt. Hallo Sasha, hier ist eine Arbeitsskizze für dich, wie du eine Galionsfigur für dein Modell entwerfen kannst.
Wenn ich also jemals wieder etwas baue (sofern ich Zeit und Gelegenheit dazu habe), dann natürlich nach Abschluss meiner aktuellen Projekte, und zwar die Brigg Le Faune von 1805 (nach Le Cygnes Monografie) mit einer Galionsfigur wie dieser...
...wenn ich nur wüsste, wie man es macht))) aber das ist eine andere Geschichte.
THAT would get me to try it. Until then, saws, burrs and chisels. I don't understand my own thinking here though. For my current project because no aftermarket supplier can provide 44 perfect, exact pattern, size, cypher etc. in Commonwealth pattern metal guns I am good with resin printed or cast resin cannon. But I am not happy with the idea for my own model for a single resin printed figurehead. Am I alone on this? I know full well if this kind of thing was available to 18th century model ship builders, some/many/most would use it without question. Then again, maybe it is time for a change for me. This brings up a question. What color was the common crowned lion figure head used on ships named after towns painted? Was there a written standard? If they were always painted, why bother carving it out of wood? I found the following
White and Gold: The most common and cost-effective finish. The lion was painted solid white with gold leaf or yellow paint applied to the mane, the royal crest, and other decorative accents.
Natural Wood & Yellow: Some lions retained the natural carved wood or were painted a pale yellow (yellow ochre), with details like mouths and flags highlighted in red and blue.
I want to disappoint you, before all the wood was painted, except for the deck! And it was painted with pig paints and there were also wild chemicals inside (these paints have long been banned at the legislative level), but these paints prevented rotting, at least in comparison with ordinary ones. So, if you look at the authenticity, then we need to paint everything, but this is not right in my opinion and I do not like it at all. And the figurehead can be covered with copper and made a patina to look antique or gold. Or choose a good paint and do artistic painting using the dry brush method and dilution to play with shadows and light areas. Sometimes this looks much better than a wooden figure carved with an ax (may all novice carvers forgive me), but this is IMHO. I am much more attracted to the silhouette, detailing, clarity and accuracy. Yes, if it is wood with a gorgeous cut, then here this is definitely the best option. But if this is not possible, then proper good painting with shadows is the only option for me personally.
