- Nov 18, 2025
Thanks for your kind comments MikeExcellent job beautifully done.
Andi
Thanks for that Kurt, Tried painting to start with but after using the brass black and seeing the results decided it was much better effect with the brass blackGreat looking brass work, I will have to list the process for trying at home as my brass just doesn't look as good.
Hi AndiThanks for that Kurt, Tried painting to start with but after using the brass black and seeing the results decided it was much better effect with the brass black
Thank you very much for your comment, its a great kit to build and considering progress made to date and the fact that I am putting in about 4hrs a day the finish line is a long way off yetWonderfully clear illustration and description of technique. Following with much interest.
Hi Gilbert,Hi Andi
Great work on the Victory, congratulations.
What I did on my build (see here) was to use brass black first and then one coat of black acrylic paint.
Cheers
Thanks for that info AllenHi Andi,
Maybe too late now, but for next time??![]()
The trucks were set up so they did not fall off the axle trees when rolling. Linch (lynch) pins were used to prevent this from happening but this requires the trucks to be closer to the brackets. Not sure if Caldercraft addresses this. The axles were rounded for a long enough portion to allow the trucks to be pushed in place with room remaining outboard for the linch pins and axletree hoops.
Glad to help. If you have not already seen it, check out the Tricks of the Trade topic here at SoS and scroll to making round axles. Makes it easy to get rid of the square ends on the axletrees. https://shipsofscale.com/sosforums/threads/tricks-of-the-trade.15492/Thanks for that info Allen
Thanks for that Allen. Have just checked out the item on tricks of the trade, what a neat little tool that does a great job, however i found that after fitting the wheels to a square axle and being very careful painting the end of the axle black the axles do look roundGlad to help. If you have not already seen it, check out the Tricks of the Trade topic here at SoS and scroll to making round axles. Makes it easy to get rid of the square ends on the axletrees. https://shipsofscale.com/sosforums/threads/tricks-of-the-trade.15492/
Thanks for that Grant but I made a mistake with the planking. I started at the stern and planked up to the skid beam frame and then went to the bow end and did the same, planking up to the other end of the skid beam frame. It was then that I realised that the 4 butt (plank) system I was using ( 2.5mm, 5.0mm, 7.5mm and 10mm) didn't match up with the section of planking from the stern end to the skid beam assembly. So I ripped up all the planking from the bow end up to the skid beam frame. However, all is well now and I have completed the planking and will add the photos soonLooking very good Andi. Kudos. Cheers Grant
