Unless Jack is positioning himself to compete against ropes of scale?
oh probably. But I don't care. I am having funThis is in no way a criticism, because the doing and learning are rewards in their own right, but the cost of the ropewalk (including thread) most be approaching the cost of a lifetime supply of rope.
absolutely not. Just having some funUnless Jack is positioning himself to compete against ropes of scale?
For Q1, I think you are asking the difference between cable laid and hawser laid rope. Cable laid is rope made with usually 3 hawser ropes. And hawser ropes is rope usually made with 3 strands.Jack,
Since you're doing a lot of research on the subject of rope making, maybe you're the one to ask these questions..
But first, some background:
I was about to start serving the rope for the main shrouds when I realized that the 0.040" rope that came with the kit (WP 1215) seemed quite a bit thicker than the 0.043" "cable" from Ropes of Scale that used for the pendants. The RoS poly cable also has a more wraps per inch than the MS rope. I like the look of the RoS cable better than the kit MS rope. Unfortunately, I don't have enough of it to rig the lower shrouds on the main, let alone the rest of the ship. So, I went online to shop for more material. But I don't know what to get.
Q1: What's the difference between rope and cable laid rope?
Q2: What's the difference between right handed and left handed rope?
Q3: If the available options are limited to 3 ea. 5m lengths of the 1.00mm poly rope, or a seemingly unlimited supply of 1.00mm in cotton, which would you get?
My questions perhaps are much more basic than even that.For Q1, I think you are asking the difference between cable laid and hawser laid rope. Cable laid is rope made with usually 3 hawser ropes. And hawser ropes is rope usually made with 3 strands.
For Q2: Z twist and right twist are the same thing. Similarly s twist or left twist are the same.
Does this diagram help:
For Q3: I don't know. I am used to working with the stuff in kits which is usually cotton and I don't like it. I purchased several sizes of poly and that is what I plan on using for the Constitution. I suppose I could try to make some ropes with cotton but I don't have any cotton strands available.
That's what I know about this.
I am curious. Is the cable laid rope more expensive? It would have more twists in it and therefore stiffer rope.My questions perhaps are much more basic than even that.
I can buy what Ropes of Scale calls "rope" or I can buy what ropes of scale calls "cable". Ultimately I can get either in the same diameter, and I can't tell the difference between the samples of both that I have. So, it doesn't seem to matter which I choose.
Likewise for S vs Z twist. I can get either of the above with either twist. I was just wondering if there was some reason for the differences apart from esthetics.
Since the cable that I used for the pendants is S-twist, I guess I will get the same for the shrouds and on the matter of cable versus rope, I'll buy whatever has the more available stock on hand.
Thanks
I'm less concerned about authenticity than I am about availability. Given the turn around time, and the limited stock in any of my options, I guess I'm going to go for whichever RoS has the most of to get me started, and go back on subsequent passes to replenish what I run out of.So Z twist cable laid rope may not be useful for the constitution.
DId you check the museum site to see what they say?
Yeah there is definitely not enough rope given with the kit. I can confirm thatI'm less concerned about authenticity than I am about availability. Given the turn around time, and the limited stock in any of my options, I guess I'm going to go for whichever RoS has the most of to get me started, and go back on subsequent passes to replenish what I run out of.
FWIW to those who are following the Hunt practicum. If you follow his instructions on how much 0.40" dia. black rope for the shrouds and the swifter for the main alone, that would be 40" for the swifter, and 32" for each of the shrouds pairs - and if my math doesn't fail me, that works out to 27.33 yards. The kit provides 15 yards for the entire project, which would naturally include the foremast. If you're stocking up on rope, plan well ahead...
Thanks Jack, and sorry for cluttering up your log and distracting you from the joys of rope making.
In the FWIW category, I asked Ben those questions once and here's the response he gave me.Q1: What's the difference between rope and cable laid rope?
good information. thanksIn the FWIW category, I asked Ben those questions once and here's the response he gave me.
I think the only left-hand rope you would find out in the real world are actually cable-laid ropes, three right-hand ropes twisted into a left-hand cable. I make left-handed ropes because people asked for them. It turns out my cotton threads make a nicer left-hand rope and right-hand... It's the opposite with my polyester threads.
i just realized even if I do this, I still will not have a true ztwist hawser because the mara strands are not monofilaments either. they are z twisted filaments. lol. too funnyi am going to try and untwist the mara thread individually with the strand holders in the machine and turn it into an s twist mara strand.
repeat for the other two bobins and then make my z twist hawser rope. I have succumed to the will of the rope gods!
Talk about confusing...Granted, this knowledge comes from a work of fiction, but in one of the Master and Commander books there is big fuss made about the difference between hawse laid and cable laid ropes, that being simply the direction of the twist. Ironically, ropes seem to be hawse laid, whereas hawses are cable laid, if I’m remembering that correctly. Someone please correct me to 100%.
