Soleil Royal- Re-engineering Artesania Latina's New Kit by NMBROOK
Thanks for the update on Proxxon, Nigel. I've nearly always used Chronos, very sad - still we all know where to lay the blame! I've also used RDG, which I guess is your 'supplier'.
Hopefully I won't be needing to buy more.
Stuart
Hi Stuart
RDG only have a small amount of Proxxon in stock and incidentally are quite a journey from my house.
The mill components came from PTC tools in Liverpool with lightning fast mail order
Everything else from Greenvill crafts in Harrogate. They are just down the road from me and are a woodworking tool specialist. They said this morning if they don’t have it, they can get anything in the catalogue in two weeks. Good to know and to be honest they had the biggest selection of Proxxon I have seen on racks anywhere. However they had sold the vice I think I am going to buy for the mill, so we will see how they go on if I preorder one
Kind Regards
Nigel
quite the mill. must put the mf70 to shame...
Hi Jack
Yes but I would stress the MF70 lasted 14 years before becoming unusable. She screams like a banshee now and snaps 1mm cutters immediately due to the runout. Milling mortices on the Saint Philippe frames in 1/36 was probably too big an ask.
Kind Regards
Nigel
Good to read, that you‘re back Nigel. I use your new Proxxon equipment for more than 15 years. The mill works fine. The only thing I changed were the milling cutters. I use now the same as for my CNC.
Hi Stuart
Kind Regards
Nigel
Why not order direct from Proxxon? I do, and it works well. They have never been out of an item, and they are quite friendly.
Hi Jack
Kind Regards
Nigel
Hello,
Nice to see you are back.
Glad that it lasted that long. I have one as well. I bought a kit 7 years ago to convert it to a CNC machine, but I have not done anything with that. It's one of my many side projects that hasn't gotten any traction yet...
Hi William
Because it works out far more expensive when you add shipping, import duty and tax.
I dare say it may work out a similar cost to buying local for you in the US but in the UK, any order over £100 gets hammered.
Kind Regards
Nigel
Hello,
The biggest issue on the MF70 is backlash on x, y and predominantly the z axis. From the videos I have seen, fitting a stepper motor eliminates the problem as the main issue is slop in the handles. You can close this up but then need to fit thrust bearings otherwise the handles become too stiff to turn. They do work really well though as CNC and Proxxon offer a CNC version
Kind Regards
Nigel
Kind Regards
Nigel
well i have the thrust bearings i just haven't installed them, but if I install the steppers I would imagine I won't need them.
Thanks everyone for the welcome back:)
I have been working on the lower Spiral staircases. This gives me chance to get my head around all the other aspects of the fit out of the lower deck. My original intentions are slowly coming back to me.
I cover the basic assembly previously.This assembly needs to remain a removable sub assembly until the deck beams are fitted permanently but as much as possible needs to be added now as it would be next to impossible to carry out the work inside the model.
I have profiled the base to suit camber and sheer of the deck below and finalised the top step to match the sheer of the deck above.Trim rails have been added above and below the stringers.
I deliberated a lot about the spindles and anything I could make would just look too "clunky" and spoil scale fidelity. I opted to use 0.8mm plain brass rod which will later be painted to match the boxwood. Holes were carefully drilled in the middle of the stringers to take these spindles.After gluing in, they have been trimmed to height and the bevel added to follow the rail which is yet to be fitted. I intend to make the rail from 0.6mm Box veneer.
Kind Regards
Nigel
