- Aug 19, 2024
Thanks for your input, Frank.
I know what you mean. On the 74-gun ship, these battens are continuous—meaning just one long batten each. I was able to identify this type of batten from the plans and other build logs for the *Artésien*. They were installed individually. I’m not sure why they did it that way, as I suspect it results in a loss of structural integrity. Here is another excerpt from the plans. You don't see any dashed lines for these battens here—lines that would indicate they consist of a single piece. This same method was also used on the L'Anemone. Perhaps continuous battens were only used on larger ships, given that the *Artésien* isn't a 74-gun ship.
Regards
Andreas
Regards
Andreas
