IJN Pre-Dreadnought Battleship Mikasa by Merit 1:200 with Pontos and KA Models
Good morning, Paul and Chris.
First of all, thank you very much, Paul—that’s very kind of you.
Chris:
No, as far as I know, Zeiss Jena did not supply rangefinders to the Imperial Japanese Navy for the Battle of Tsushima. Instead, coincidence rangefinders from the Scottish firm Barr & Stroud are credited with the Japanese forces' superior targeting accuracy.
However, there is indeed a connection to Zeiss Jena—not involving rangefinders, but rather the admiral's binoculars: during the battle, Japanese Fleet Admiral Tōgō Heihachirō wore a famous Carl Zeiss Jena "naval turret binocular" around his neck. These binoculars were a top-tier personal instrument and can still be seen today on the museum ship *Mikasa* in Japan. Since Tōgō used them to keep the Russian fleet in sight, the Zeiss name was frequently mentioned prominently in reports.
I imagine that is how this piece of misinformation might have originated.
Before I can turn my attention to the masts, I have to attend to a mundane but necessary task.
The model still needs protection against dust, as it will be several weeks before I finish the *Mikasa*.
Up to now, it has been sitting under a simple, custom-cut cardboard cover. For a project spanning over two years, this is essential.
Now that the masts are to be installed, more vertical clearance is required. So, I got a second piece of cardboard, cut both to size, and joined them together. Everything is held in place and reinforced with duct tape.
Of course, it is important to measure everything precisely beforehand—to avoid any contact between the masts and the cardboard later on. I’ve marked the positions on both the model and the tabletop using a permanent marker. This ensures the model is in the right spot when I slide the dust cover over it.
As you can see in the following picture, the ship’s layout isn't perfectly symmetrical. That explains the markings and the generous cutout in the cardboard. This way, there shouldn't be any issues once the masts are fully installed.
And so, I believe the model is well-protected against the looming threat of dust bunnies while it awaits completion.
Beautiful and stunning modelling.
With those masts in place, she’s really starting to look like a proper pre-dreadnought. Beautiful work! Can’t wait to see her finished.
My dear Wieslaw, thank you. In that case, I'll go ahead and continue working on the masts.
After a forced break due to illness, I can finally get moving to it. Let's start with the mainmast; it’s more complex than the foremast because the derrick boom needs to be installed on it.
Here is the first quick update.
I’ve got everything prepped and laid out for the job.
The intricate block-and-tackle assembly—featuring those photo-etched ropes—is actually really nice, but I can't use it as-is. You might recall that I attached the derrick boom to the lower section of the mast quite a while ago. There were structural reasons for doing that, but it rules out using the photo-etched parts in their current form.
So, I’ve cut everything off and am assembling the pulley blocks without the photo-etched ropes—more on that later. I’ll simply use rigging thread instead.
Let's start with the base. It’s straightforward work, thanks to the perfectly fitting rings and well-designed photo-etched ladders from Pontos.
Now for the first delicate assembly step: the gusset plates beneath the platform. I put together a small jig to hold the mast upright while I attach the parts under the platform.
It’s already looking great. I love the level of detail Pontos provides.
I’ve also installed the pulleys for the rudder angle indicator and the railing.
And this is how the two yardarms can be threaded into place.
That wraps up my quick introduction; now I can admire the fine brass component a bit more before continuing with the build today.
However, I’m going to assemble the foremast to the same stage first, before the complicated part on the mainmast begins.
Thank you so much, wieslaw.
Here is another quick mini-update for today.
The basic structure of the foremast is essentially complete, meaning the sails could theoretically be set.
To check that everything is aligned at the correct angles, I’ve positioned the masts in their respective places.
It looks really good. It gives the ship a towering profile—significantly more mast than on my *Bismarck*, for instance.
Just as *Archaeopteryx* is to birds, the *Mikasa* represents the missing link for me—bridging the gap between venerable sailing ships and the modern steel behemoths of the twentieth century.
Now for the finer details.
Here is the next quick update.
This is the last major component that is quite complex to fabricate. That’s why I share these small interim results regarding the masts; I’m usually just relieved to have finished a particular section without any major mishaps.
It almost happened a little while ago.
While I was trying to add some highlights to the chipping points, the visor of my magnifying glasses bumped into the wind vane at the top—and *snap*, it was bent. Fortunately, it stayed attached and the "carpet monster" didn't eat it.
It wasn't a huge deal to straighten it back out, but it was annoying nonetheless. You have to be incredibly vigilant with these delicate, awkward mast components.
And that’s despite the fact that I mount the brass masts in a handle to make working on them easier—like here, where I’m painting the photo-etched yard ropes black.
So, the base coat is applied, and they look absolutely fantastic.
After some subsequent weathering, the basic structure of the masts is complete.
The signal gaffs will be attached to the masts later, as they would only get in the way during the next assembly steps—namely, the searchlights, the sailor figures, and the backstays for the upper sections of the masts.
But that’s it for today.
Let’s move on to the next small step.
Before I can secure the upper masts with the backstays, I need to finish all other work on them. This includes mounting two of those fantastic searchlights from Micro Master onto the platforms.
To remove them cleanly from their support structure, I always tack them onto a small PVC sheet using double-sided tape. This ensures a secure hold while peeling these delicate structures away from the excess printing supports.
The climbing aids needed to reach the very top of the masts were still missing. According to the assembly instructions, they are supposed to be attached to the sides. I changed this for two reasons.
First, this configuration cannot be confirmed by any photograph of the *Mikasa*. However, there is an excellent, high-resolution photo of the *Azuma* showing them positioned exactly as I have them now—attached at the rear.
Second, in my opinion, the side-mounted arrangement doesn't work well with the yardarms, as the climbing aids would have to pass right by them. So, this is the solution I came up with:
Then, a bit of manpower was needed—a lookout keeping a sharp eye out:
A sailor climbing up:
And there seems to be a problem with the searchlight:
And with that, the basic assembly of the masts is complete.
Tomorrow, I can install the upper backstays.
Moving on to the masts!
All that’s missing now are the upper backstays. This time, I’ve decided not to use the lines provided in the photo-etched parts set; instead, I’m crafting them myself using rigging thread. In my opinion, this looks more cohesive and fits better with the overall appearance.
I’ve prepared everything accordingly—repurposing some railing stanchions, which I’m using as makeshift line tensioners.
This simple solution makes the work significantly easier, and the results are well worth it. A major advantage is that I can create an entire pair of backstays using a single, continuous thread. This saves effort while ensuring a clean, neat look.
To make the rigging thread easier to see in the photos, I took the next few shots against a white background. Here you can see the foremast, now fully equipped with all twelve backstays.
With that, the first mast is completely rigged—a great step forward!
Next up: the mainmast.
At first, I was a bit cautious when tensioning and pulling the individual lines—after all, everything needs to sit properly and look uniform in the end. But as is often the case, practice leads to routine; by the end, the work was progressing quite quickly.
And before you know it, the second mast is finished, too!
With that, the rigging for both masts is complete, and they are ready to be placed onto the model.
Next on the agenda is the crane, complete with its pulley system.
Looks like another little challenge awaits! I’ll be sure to keep you posted!
A lovely Sunday to all my fellow ship modellers and many thanks, Peter!
For me, today has turned out to be a particularly wonderful Sunday, because I’ve managed to take a small but very satisfying step forward with my build. To be honest, when I first started thinking about it, I wasn’t entirely sure how to tackle it properly. All the more reason to be pleased with the result, and of course, I’d like to share it with you. So today, I have a very short build update for you.
But let’s take things one step at a time!
I had to come up with a solution for the tackle on the crane boom. Since I’ve made some fairly substantial changes to the original build sequence of my model, I could no longer use the photo-etched part originally intended to represent the block-and-tackle assembly. And to be perfectly honest, I’ve never been particularly keen on those flat, two-dimensional ropes represented by photo-etched parts anyway. So, I needed to find another solution!
I therefore took the photo-etched parts apart and separated the blocks from the running lines.
So far, so good. But now came the real challenge: making my very first block with a proper sheave of my own!
Incidentally, I hope I’m getting the terminology more or less right this time. If not, please feel free to correct me!
First, I rummaged through my old box of photo-etched parts. And lo and behold, I actually found a few suitable sheaves that were just right for what I had in mind.
Next, I dismantled the photo-etched blocks further until I had the two halves of each block separated. I then soldered a suitable sheave onto one of the halves.
After that, I put the second half back in place. I also inserted a small piece of profile at the top to form the attachment point for the eye. This allowed me to solder everything together neatly without distorting the delicate little component.
And then the moment finally arrived: my very first scratch-built block with a proper sheave was complete!
I’m already really pleased with this little prototype. At last, a nice, three-dimensional sheave that actually looks the part!
And now comes the real icing on the cake for me: I can simply reeve my rigging thread through the block. No more flat, photo-etched appearance — just a solution that looks much closer to the real thing.
In theory, this means I’m now even able to make a proper tackle — or, to be more precise, a working purchase! And with my crane boom, I could actually lower one of my lovely 3D-printed pinnaces into the water, if only the boom weren’t glued firmly in place!
And all of this in 1:200 scale!
What makes me particularly happy is that I haven’t simply settled for some sort of compromise. I’ve found a solution that works well both in practice and in terms of appearance.
If this isn’t a fantastic Sunday, I don’t know what is!
I wish you all a lovely and relaxing Sunday. And, as always, suggestions, tips and constructive criticism are more than welcome!
The moment has arrived.
The masts are in place, and my *Mikasa* is gradually taking on its final profile. Another milestone reached!
Aligning the masts, however, was a bit of a nerve-wracking experience. Everything had to be positioned precisely within the short working time of the adhesive—a trade-off for having installed the lower third so early on. But as you can see, it all worked out perfectly!
Afterward, I carefully laid the ship on its side to clean up and conceal the seam on the mast. From this point on, the utmost care is required at every step to ensure that the components already installed aren't damaged. My assembly stand continues to be an invaluable help.
Next, it was time for the remaining pulleys—soldered…
…and then painted. These small components will later contribute to a cohesive, well-balanced look for the rigging.
For the next step, I’ll be using the blocks to assemble the complex tackle systems for the crane boom. That brings us one step closer to completing the rigging!
So, fellow modelers, stay on board—there’s still plenty to do!
Back again!
Since assembling the blocks into a complete tackle system went much more smoothly than expected, I’ve got another quick update from my shipyard today.
To be honest, I was a bit apprehensive about this particular step. Normally, I could have easily prepared the entire block-and-tackle assembly beforehand and then mounted it onto the model along with the mast and boom. However, due to my slightly modified construction approach, I had no choice but to thread the tackle into place between components that were already installed—not exactly the most convenient starting point, considering how delicate everything is!
As you may recall, I had previously modified the blocks, turning the original two-dimensional photo-etched parts into three-dimensional sheaves. While that was initially just an aesthetic choice, it turned out to be a stroke of pure luck.
So, time to get to work! First, I attached a long piece of rigging line to the first block…
…and then proceeded, sheave by sheave. By carefully threading the line through each block, the complete tackle system gradually took shape. A small piece of adhesive tape helped keep the line under tension, ensuring that the sections I’d already threaded didn’t slip out of place. Sometimes, here in the shipyard, you just have to conjure up a third hand for yourself!
But as I turned the model around, a question occurred to me—one I’d completely overlooked in my excitement over successfully threading the line: where exactly am I supposed to secure the loose ends of the tackle?
But a simple solution was found for this, too. At the point where, according to Pontos, the photo-etched cables were supposed to be attached, I simply added a small eyelet. This allowed the thread to be secured neatly and the tackle to be finished off properly.
And with that, another delicate component is on board! With such intricate work, I’m always relieved when everything ends up in its intended place without anything being accidentally bent or damaged.
I think the result is well worth seeing—the tackle looks really sharp! The three-dimensional blocks stand out much better, and the overall arrangement looks clean and well-proportioned.
I’m especially pleased that the tackle now hangs from the mast at exactly the right angles. This marks the successful completion of this small but significant part of the rigging process.
Now, it’s time to move on to the main rigging. Let’s see what little challenges the next phase in our shipyard has in store!
Let’s move on to a stage of the build that I’ve been giving quite a bit of thought to for some time.
It all started when I installed those extremely delicate brackets with the small sheaves on the platform’s gusset plates. By that point, I had learned that the rudder angle indicators would be rigged through these little sheaves. And that got me wondering: Would these delicate structures be strong enough to withstand the tension of the rigging later on? After all, I didn’t want the first parts to snap off as soon as I started tensioning the lines.
As it turns out, my concerns were fortunately unfounded! But more on that in a moment.
Before the rudder angle indicators could come aboard, however, the small signal bodies first had to be made. And that’s when my friend Ingo from a German forum came into the picture. He very kindly used his new resin printer to print several of these signals in different sizes and sent them over to me.
A big thank-you once again, dear Ingo! This kind of friendly support is what makes our shared hobby so enjoyable.
The next step was to drill a hole in each of the little signal bodies so that the rigging thread could be attached. Cleverly, Ingo had already included a small centring mark in the printed parts. This made it easy to position the drill right in the middle without having to fiddle around too much.
A tiny drop of superglue in the hole, the rigging thread inserted, and the connection was made.
Naturally, I wanted to make sure everything would hold before installing the signals. So I gently applied tension to both of them to test the strength of the glued joints. After all, the rudder angle indicators should not only look the part but also withstand the tension required for the lines to run properly.
The test was successful, and while I was at it, I gave both signal bodies their finishing coat of paint.
With all the preparation taken care of, it was time to get them aboard!
Thanks to the relatively large scale of the model, installation turned out to be pleasantly straightforward. All I had to do was lead the rigging threads over the sheaves already mounted on the brackets and then secure the lower ends.
And there you have it! The delicate brackets held up without a fuss. My initial concerns really were unfounded after all. Sometimes, as a modeller, it’s nice to be pleasantly surprised!
And so, another small but lovely detail has been added to the ship. One more step on the long journey into the wonderful world of rigging is complete!
Until the next stage of the build, mates!
Hi everyone!
Back in the workshop, we’re moving on to the next big step: we’re attaching the guy ropes. Once again, the assembly stand is a huge help here. It works perfectly as a hand rest whilst tying the knots, or keeps the lines neatly taut with the help of a bit of adhesive tape.
Let’s keep it brief for now: all the backstays and signal lines at the stern have been successfully fitted! I pulled the signal lines using white rigging twine and then dyed them with a brown wash.
I simply can’t get enough of admiring this complex, delicate web of threads. It’s absolutely fascinating how all these details breathe life into the model.
Unfortunately, the next minor setback wasn’t long in coming. Towards the bow, the cutters and the guy ropes got in each other’s way. So I carefully removed them from the boat decks again. It’s a good thing I rarely use superglue these days.
I’d actually done a lot of test fittings with all sorts of components beforehand. Precisely because I realised I’d made quite a few changes. But as you know: you only find out whether everything actually fits together in the end during the actual building process.
And in this case, the cutter was simply a good bit too far forward. The green arrows show exactly where the boat cradles were originally positioned.
But as we all know, there’s nothing an ambitious model-maker can’t sort out! So, without further ado, I fetched some paint and a wash, painted over the old marks and repositioned the little boat. And lo and behold: it fits perfectly again and the rope runs past it smoothly.
Everything’s back on track – time to get on with threading the ropes!
Hi everyone!
Hi, it's really nice—clean and well-finished. Congratulations. Happy modeling. Frank
Hi everyone!
As a ‘rigging-lover’ I am always impressed by the amount of lines that’s rigged on this type of ships. You rigging looks great, Joelle. And making adjustments during a build is part of the life of a scratch- of ‘kit-bashing’ (in the most positive way) builder.:)
