Hi Dave. Many thanks for your invaluable 'show and tell', If it not too much time, can you get into details on how to make an octagon from a square using the table saw?The first step is to cut a piece of 5/16" square boxwood into an octagon on the table saw.
Hi Dave,Hi Jim!
Let me start by saying that I LOVE my Byrnes saw! It is the best designed and machined tool that I own, and that includes all my full sized power tools. The only shortcoming the Byrnes has is the lack of a tilting arbor! The only way to make angled cuts on a Byrnes is to use the "tilt table" attachment. It is fiddly and takes forever to set up. I used it once, and I've not used it since. I went out and bought a Proxxon FET saw with a tilting arbor!
Cutting an octagon is easy. First make sure you have a piece of wood with a square profile exactly the same size as your finish piece. Something soft like pine or bass wood works well. You'll set up the angle of cut and the fence on the "scrap" piece before cutting your good stock.
Set the blade angle to 45 degrees and set the fence so that when you push the wood into the blade while holding it against the fence, you cut off a little of the the lower corner of the piece that is away from the fence. Turn the stock 90 degrees and cut off another corner. Look at the top three facets you've created. You want them to be identical. Move the fence toward the blade or away from the blade in small increments until they are. The cuts only need to be an inch or so long, so when you make an adjustment to the fence you can cut off the end and start with a "fresh " blank.
Once the fence is set, rotate the stock 90 degrees and cut off the remaining two "corners". The little octagon I cut in the pictures took me less than 5 minutes to do. One thing, though. You should have a zero clearance insert for the 45 degree blade angle. Proxxon gives you one extra, and you can order more. Simple!
View attachment 105459View attachment 105460View attachment 105461View attachment 105462
Thanks, guys!Hi Dave,
I fully endorse your comments about the Byrnes Saw - it is brilliant.
As you say, the only drawback is the lack of tilt capability, and the tilt plate he provides is awkward to use. I've also only used it once!
I also have his thicknesser and sander, and I'm using them all the time. They cost a bomb to import from the US, and I have to run them using a step-up transformer to suit the voltage in the UK, but still worth every penny.
For octagons and the like I use a home-made travelling jig, probably similar to the one David Lester mentions, and generally made-up at the time to suit the job.
Great work on the cross-section - following with great interest - your workmanship is superb!
Ted
It is hard to show this detail in a model, but already seen......Hi Dave, I like the sorter... One more thing if you don't mind. Originally the mats were assembled from a series of square timbers joined to each other. Since you will show just a fraction of your masts, it makes sense to show it as the original construction. What do you think?
e to
