Great work carlosys, very well detailed.
I agree too,looking good and and you are a fast builder
Hi.Very nice Carlosys, i like your fence with with the Gate way, are you going to blacken your cannon or leave them as they are,
best regards John,
Hi UwekLooking very good - great general appearance.
You have to pay attention only on your tree-nailing pattern -> I guess you nail the plank before you install your plank at the model. So sometimes your nail is not over a beam, but nailed into the air under the plank
Which method are you using for the treenails - the color difference to the plank is looking very realistic !
Why not plank the hole model,is it not enough material?
I want to plank it all!
Yes,but is there enough planks for the hole model you think?Hi.
Thanks for your comment.
Regards
Hi Uwek
Thank you. Regarding the issue of nail I'm not offended, on the contrary, the criticisms are always well received.
The wood is stained with cherry. Once dry, I apply a thin layer of varnish satin with an airbrush.
Regards
Hi Larsa
The objective I'm looking for is to see in detail the different parts that are part of the structure of a ship.
Leaving gaps open allows you to see them and understand how they were built.
Regards
I think you can easily check this with counting the necessary planks on the cross section and compare with the delivered strips - I did not do it until now, because I want also to keep parts open to see the entire structure - Otherwise a POF (Plank On Frames) would be not necessary, the construction would be much easier and faster to build the section as a POB (Plank On Bulkhead)!Yes,but is there enough planks for the hole model you think?
Thanks UwekLooking very good - really good![]()
