ZHL Chalupa 1834 (my 1st model) [Completed Build]
Yuri, the way you do it - a great way! Thumbs-Up You don't want to rush... Always try to lay first layer planks as this will be the ONLY layer.
Very good looking work with the planking - like JIm mentioned already Thumbsup Thumbsup
Here is update on my little progress. I decided to "pre-made" 10 planks at a time, looks like they fit nicely without much adjustment. Just shave a bit the angle and bend. Please don't go hard on me :) , I'm still learning and another "finish" layer will cover some minor mistakes, I hope ...
I did find these from PENN TOOL.
They are made in India, The ones in the pic are the 2 1/2". I ordered some 2" as well, but they were back-ordered.
I'm pretty fussy about the "feel" of precision hand tools. These clamps are well made and work nicely, but the corners and edges were very sharp or squared off. The two old L S Starrett ones I had in my machinist's chest have nicely rounded and tapered edges,
so, I took these apart and in a few minutes each, rounded the edges a bit on the 1 X 42 belt grinder. They feel much better in my hand now and the fact that the grinding took off some of the blackening does not bother me at all. I've seen these clamps that are polished all over, maybe they were even dull chrome plated. With some more time, I could buff off all the blackening on these and polish them up, but it's not worth it. I'm satisfied with them.
EJ
Finally had time to finish "plywood" planking and I'm getting ready to do second layer with veneer. I will be replacing some materials from the kit. I've got real complains to ZHL about materials quality and drawings accuracy. Significant problem is with different scale between kit and drawings ( almost 8 mm in length, see 1st picture below) Not sure if its worth writing separate kit review at this point..
So, here it is:
Hello.
Here is May 28 update. I just realized it took me almost a month to do veneer planking. I'm the lucky one working almost full time in IT, System administrator..
I have a few questions:
- Do i varnish/finish now or after everything is done?
- Would like to know opinion on "nailing":IMG_9018.jpg
And here is another issue with the kit. I was able to match 16 when needed 14 planks by color and grains, still with minor defects :
Gluing, banding and drying wet plank at the same time
Most planks bent "sideway", like last one:
600 grid sandpaper finish:
Thank you,
Very good planking job: accurate and clean!! Thumbs-Up
Hello Yuri,
- It depends on what type of varnish you are planning to use. If oil-based, then varnish the hull at the end of the build, because you will hard time to glue other pieces to the hull. However, if waterbased treatment, then you can do it now.
- Personally, I like copper wire. Alternatively, you can try wood filler (similar or close color) in the predrilled holes with pencil marks.
WONDERFUL PLANKING JOB ESPECIALLY THE VEENER, i just can not see myself working on the VEENER on second planking, BTW youre approaching SPILING OF PLANKS WITCH TO ME IS THE REAL WAY TO PLANK A MODEL GET THE SMALL BOOK BY JIM ROBERTS FROM MODEL EXPO TELLSNYOU HOW TO DO CORRECT SPILING WONDERFUL BOOKLET easy to understand and BTW what kind of tape is that that you were using, like it, can you right on it. GOD BLESS STAY SAFE Don
Hi Yuri!
Very well done. :)
For sealing I take nitro paint with thinner. Difficult areas are painted with a brush and then everything (without rigging) is painted with the airbrush.
As nails I use brass, copper or wood paste. Also all mixed together. In these photos they are brass and wood paste. The brass nails are not blackened, but already 25 years old and therefore they became black under the varnish.
Pump made of brass naturelly oxidized without verdigris, like the nails.
With best regards
Thomas
