Excellent work! I am starting to think there is nothing you can’t make!
Such exquisite detail everywhere!
Again, amazing details, François. Hats off!Did the tail lights and head lights today.
The tail lights in the kit are very different from the ones on the ref car so I had to redo them. The front are not do bad but I still modified them alot.
The kit's tail lights View attachment 367562
The ref car tail lights View attachment 367577View attachment 367578
I had to redo the mounting post with the mounting clamp, redid the bezel in aluminium and added the wire with ties.View attachment 367580View attachment 367579
The kit's front lights View attachment 367571
The ref car's View attachment 367575View attachment 367585View attachment 367576
For the front, I changed the mounting post from a plastic stud to an aluminium post, made an aluminium bezel complete with clamp, added the wire all the way to the buld (the bulb and wire can be seen thru the lens), reproduced the blue tape glued to the lens and added all missing bolts. For now, I used blue masking tape to do the criss cross but I'm waiting for custom made decals, I'll see which is best.View attachment 367582View attachment 367587View attachment 367581View attachment 367583
Finished the day by installing the exhaust and painting the steering wheel (don't like the color I choosed for the steering, I'll have to redo it).
View attachment 367589View attachment 367594View attachment 367595
That’s like looking at a photo of the real car! Amazing work!Thank you all!!
Made a small improvement to the head and tail lights. First, I replaced the small wire with a bigger one since a light has 2 leads hooked up to it. I but in a black and red instead of just the one black.
Bigger wire with black and red lead to bulbView attachment 367855
Second, I replaced the tape on the lens. It was too thick (.084 inche scaled up to 1:1) and too pale blue to my taste by a very thin Rice paper tape (.024 inche scaled up).View attachment 367854
Did a few more add ont to the base model. The kit provides a breather tube that goes from the transmission to a small scoop mounted on the top bonnet. When compared to my ref car, the scoop is too forward and the tube too straight, it should be bent towards the rear and have a funnel at it's end. Like on this picture. View attachment 368639
I also added a very thin black tape to simulate the bonnet gasket complete with screw heads.
my version of the breather tube
And black bonnet gasket
Scoop location of kitView attachment 368641
Where it should goView attachment 368640
Fitted and painted bonnet panels ready to be installed. View attachment 368643
Hi François. Stunning details and painting. You will make also the stickers on the screen?Didn't do much today, it was very sunny and hot so I went for my first ride of the season in the TR6, always fun. But I did take the time to do the 3 remaining pivoting clamps for the drivers side bonnet.
Clamps closed View attachment 369056
Clamps opened View attachment 369054
Bonnet opened View attachment 369055
Next on the to do list is the windscreen and rearview mirrors. Here what I'll be reproducing.View attachment 369057
The kit gives 2 windscreens but no mirrors. Should be fun!
Yes, it’s s challenge. One’s made a instruction manual for a 1:50 crane AC200-1TP:Thank you everyone for your positive comments.
Peter, these stickers once scaled down would be a about 1/8 x1/8 in each. The details would be lost. I will try but really not sure what it will look like. Hey, another challenge !!
No working gauges in the crane???? LOLYes, it’s s challenge. One’s made a instruction manual for a 1:50 crane AC200-1TP:
So, it’s possible……![]()
