Redid the shifter and hand brake lever. The kit parts were very fragile so I made them out of aluminium tubing. The hand brake handle is made of real wood, the shifter knob is a needle head that I will eventualy give a wood look. I also redid the shifter gate with the 4 requierd positions plus reverse. Also made the oil reservoir. I changed the front end of the reservoir from plastic to aluminium and added a weld bead. Also added 2 aluminium straps.
Kit shifter and brake lever
My take on it
My shifter gate next to the kit's
Oil reservoir
Also started on some mini extension springs that will be used at the jonction of the header and tail pipe. (More on that later)
My take on it
Oil reservoir
