1/12 scale Alfa Romeo 8c 2300 roadster build log [COMPLETED BUILD]
It’s looking great and very real what you are showing us, François.
Let's just say that I used a lot of 'builder's leeway' for lack of a better term.
About this quote: In the Bluenose area Dean introduced ‘Artistic License’. And a bit later we added ‘Free Interpretation’. Then ‘AL-FI’ was born, who is looking over our shoulder and nods when we have neatly 'solved' something. I am sure, AL-FI was nodding a lot of time by many of your posts. :)
Because ‘Builder’s Leeway’ sounds good, perhaps it time for BL-AL-FI. ROTF
Finaly got the dash finished. The crackeled effect was very hard to do. It took 6 tries and it's still not exactly what I was looking for but it will have to do. It stems to be an extremely random process, you can repeat the exact same steps, with the exact same thinning and drying time of paints and you will never get the same result. Here are some shots starting with, as usual, the ref car. Alfa-Romeo-8C-2300-Monza-1932-asta-71-768x576.jpg
and my version 20230212_162209.jpg20230212_153112.jpg20230212_161836.jpg20230212_161707.jpg
Then I did the front grill.
I still have a decal to install, the radiator cap and the lockwire and lockbolts.
Started the engine today. I redid the pedal assy. I kept the same plastic levers but since my intention is to have a working brake pedal, I changed the pivot shafts from plastic to aluminium. The new shafts will go thru the engine block. That way, I'll be able to add a lever to actuate the brake. Also started on adding bolts.
The kit's pedal assy
There's something missing in this kit compared to the larger scale (1/8) equivalent from the Pocher company. A working engine. So being a mecanical guy, (and nayve to much time to spare) I just could not build this engine without at least trying to but in working pistons. I know it's stupide because nobody would know they are there except me. That being said, I figure I can at least see what the cost of 3d printing the parts would be. So I started by 3d modeling an insert that would fit inside the kit's engine bloc and fitting 8 pistons, 8 connecting rods and a crank shaft. My goal would be to be able to move the pistons using the crank handle these cars had at the front. Maybe I could cut a small window somewhere on the engine block so the moins parts could be seen.
Here is a small video showing the working pistons.
View attachment 20230215_222103.mp4
Maybe you can modify some thingiverse engines. Two 4 cylinders properly scaled with a connected crankshaft would make life easier. I was considering this option for other models. I would use petg silver filament, it comes out almost ready. Hope it helps
I received the 3d printed parts I was waiting for. Not the bloc and pistons but a fuel diverter, tack bracket, radiator cap and a 4 way hydro fitting. Turns out it was pretty cheap, 20$ for 5 of each! Here are some pictures.
Radiator cap with scratch built polished aluminium bezel around the decal 20230217_204133.jpg
The tack bracket with aluminium bezel, aluminium tack face, tack needle made out of a piece of white thread and clear plastic lenze20230217_204220.jpg
The 4 way valve with piping and scratch built lever installed on dash20230217_204211.jpg
The fuel diverter (not in final location) with scratch built selector lever (the selector is a bit too wide, I think I'll redo it)20230217_204704.jpg
Did a lot of very detailed work today. I finished piping the 4 way valve mounted on the dashboard and the fuel diverter.20230218_141253.jpg
the fuel diverter
I also tried my hand at installing some wirelock bolts and twisted wire. I bought 3d printed wirelock bolts from Unobtainium in the UK. The bolts come with a correct sized wire but it's copper which is not correct. I had some 7 strand cable left over from my Shark 24 build so I removed the plastic coating and was left with 7 strands of .003in dia which come to .036in scaled up.
Did some bodywork today. I glued the cockpit to the fuel tank and installed the fuel overflow and delivery fittings. The overflow fittings are mounted on top and the kit calls for two 90deg fittings going to either side of the body with rubber tubing attached. My ref car is a bit different, it has one 90 deg fitting on the drivers side and the other looks like a breather. Instead of the rubber tubing, it as a boby colored copper tubing going down and thru the drivers side rear deck. The tubing is held in place using very small aluminium clamps.
Breather and 90 deg fitting with copper tubing on ref carAlfa-Romeo-8C-2300-Monza-1932-asta-5-768x576.jpg
Then I did the delivery tubing. Again, my ref car is different from the kit. On the kit, the two fittings are too high and have ordinary rubber tubing attached. On the ref car, the fittings are located much lower on the tank ( which is logical with the lower one being probably for the reserve) and instead of the plain rubber tubing, they have a spring wrapped rubber tubing.
Spring wrapped tubing on ref carAlfa-Romeo-8C-2300-Monza-1932-asta-4-768x576.jpg
It's starting to look more and more like a car. Here's what I did today
3- finished the fuel overflow line and a bit of wirelock 20230221_220028.jpg
5- took some pictures with a few parts assembled just for fun
First time here.....and extremely impressed with your attention to detail.
However, it's clear you've never done any lockwire work for real.
The wire doesn't just pass straight through a fastener....
Hi Francois.
I was only hinting that as you're going to include an 'impression' of lock-wired fasteners, it would be far more convincing if a short twist between nuts/bolts, set at a slight angle would appear instantly more authentic, which, after all is the impression you're after?
Please don't take my suggestion as criticism; your model is superb and a credit to your vision and skills.
Hey pugwash, don't worry, no offence made or taken. I had to make a compromise between having a nice enough looking twisted wire or a thru to reality installation. Althougt I would like for my skills to be limitless, they're not so I went with the nice enough look. I do have an idea of how I could twist the wire and have the proper install. I'ii give it a try and let you know if it works.
If it works, no doubt we'll be seeing it!
The main thing is, you're enjoying yourself and sharing your skills and enthusiasm with a wider audience.
Looking forward to the video, when you get the engine running.
