In several perspectives we can not recognize, that this is a model - looks like a real 1:1 car
Sorry, not trying to be critical...just making an observation. I think you are doing great work!I actually bought the thread for the spark plus câbles. At .5mm dia, it represents à 6mm câble which is ok fot the plugs I figured it would also be ok for for the wiring but now that I look ar the pictures more closely, I must admit it is a bit too big. I guess I knew it all along but just didn't want to admit it. I have a heavy sewing thread that could do but I only have it in black. I'lI try to find some colored. Well, it's back to the wiring board! Thanks for lights up Dean.
Another thought would be to try actual wire which will hold the shape you want. You can paint it to the color you wish. If you need it really small, look for enameled transformer wire. You can get that at amazingly small diameter!I actually bought the thread for the spark plus câbles. At .5mm dia, it represents à 6mm câble which is ok fot the plugs I figured it would also be ok for for the wiring but now that I look ar the pictures more closely, I must admit it is a bit too big. I guess I knew it all along but just didn't want to admit it. I have a heavy sewing thread that could do but I only have it in black. I'lI try to find some colored. Well, it's back to the wiring board! Thanks for lights up Dean.
A definite improvement!So, I decided to redo the wiring. The .5mm thread I used was effectively too big. Instead, I used a .25mm nylon thread that, once scaled up, come to a 1/8 in dia wire. Another change I made is the color choice. On my first try, I was trying too hard and the result came out too busy. My ref car only has one color, looks like a dark grey. I could not find a gray thread of the proper dia so I went with black. I also decided to eliminate the multi leads going from the firewall to the back and front of the car. After a little bit of research on google, I found a few pictures that show how a 1930's wire harness has a braided cover over the wires. So that's what I did. The small .25mm threads are glued to a larger .8mm braided thread. I have 4 braided lines in total, 2 per side, 1 going to the front and 1to the rear. I'll eventually add a few colored wires sticking out of the braided cover at specific areas to connect electrical componants such as the fuel pump, the battery, the starter....
A 1930's wire harness showing the braided cover View attachment 355626
My take on the braided cover View attachment 355632View attachment 355630
The result View attachment 355629
And again the ref carView attachment 355633
