1/12 scale Alfa Romeo 8c 2300 roadster build log [COMPLETED BUILD]
Here are a few more details that were done in the past days.
Installed the last remaining components on the engine, starter on the left, horn in the middle and the "whatdoesitdo" on the right. All 3 have leads that will be attached to the main harness.20230322_194649.jpg
Water pipes installed. I replaced the kit's moulded connecting tube and clamps with real rubber tube (it's actually electrical heat shrink tube) and clamps made with a chrome tape. Notice the tiny clamps screw.20230321_091216.jpg
I replaced the kit's badly moulded oil filler cap (on the right) with a polished aluminium cap on the left. Not sure if I'll leave it polished since it's not polished on my ref car.20230322_194550.jpg
Installed the last linkage, I think it's used to manualy ajust the advance/retard on the distributer (not sure about that).20230322_194526.jpg
And finally, added the link between the header and exhaust pipe as on my ref car. The kit doesn't have any. 20230322_160358.jpg
The engine is in (married) !! I started to grime it up a bit, not easy to not over do it. I'll do some more once everything is in place. I did grime up the crank shaft and pistons by using an enamel engine oil simulater but once dried, the engine would not turn anymore. But I eventually got it working again but adding very light oil. It looks the part now!! I also weathered the exhaust a bit.20230323_201135.jpg20230323_201111.jpg20230324_081514.jpg
View attachment 20230324_081351.mp4
E
Here's what I've been up to today.
Started final installation of some body panels with lockwire. (Sorry pugwash, I tried the idea I had for a more thru to life wirelock but it didn't work). Installed the floor pan. Fabricated a battery cut off switch as on ref car. Installed pedals. Continued the brake linkage, I just need to connect the brake pedal to the linkage. Added the brake pedal shaft end support. Here are some pictures.
Floor pan installed (added a few other parts for test fitting)
And it actually works!!
View attachment 20230327_202533.mp4
Removal of oil pan to show engine's inner parts (the pan is held in place using two small magnets)
View attachment 20230327_172840.mp4
The body us now on and ready for the lockwire. I've installed the steering column with it's custom gage. Wired the 3 components on the engine's left side. Finished the brake and steering linkage. Plus a few other things. Here are some pictures.
E
Boby panels with lockwire View attachment 365743
And ref carView attachment 365746
Battery cutoff switch View attachment 365742
Cutoff switch on ref car View attachment 365747
All pedals installed and weathered View attachment 365749
Ref car pedals View attachment 365748
Brake linkage View attachment 365739
Brake pedal shaft end support View attachment 365750
Love it !
Wow - absolutely incredible. I have the Romeo Monza - but I am sure it will not even come close to what you have done - very well done !!!
amazing work - just wonderful
sometimes I have to look twice to realize it is the model or the original
Still more detail work done today. Redid the tubular passthru for the spark plug wires out of aluminium tubing. The kit's part is plastic and way to flemsy. Routed all the plug wires and all the gas and oil lines. Here are todays picture.
Oil tank piping
Kit's cheap plastic tubular passthru View attachment 366166View attachment 366165
My passthru View attachment 366168View attachment 366167
View attachment 366158View attachment 366161
Ref carView attachment 366160
Oil tankView attachment 366153
Oil tank piping
Beautiful work! It’s really coming alive! ;)
Ok, so I know that many of you will say that seat belts don't belong in a 1930's car and you are absolutly right. But my ref car, which was destroyed sometime in the 30's was restored for race track use in the 70's. I assume it was fitted with these belts at that time.Alfa-Romeo-8C-2300-Monza-1932-asta-57-768x576.jpg
Here's my rendering of them20230402_130811.jpg20230402_165819.jpg20230402_202142.jpg
And Dean, I started the temp gauge probe attachement you asked for, it should be finished tomorrow.
Did the tail lights and head lights today.
The tail lights in the kit are very different from the ones on the ref car so I had to redo them. The front are not do bad but I still modified them alot.
The ref car tail lights Alfa-Romeo-8C-2300-Monza-1932-asta-48-768x576.jpgAlfa-Romeo-8C-2300-Monza-1932-asta-54-768x576.jpg
I had to redo the mounting post with the mounting clamp, redid the bezel in aluminium and added the wire with ties.20230405_173501~2.jpg20230405_173600~2.jpg
The ref car's Alfa-Romeo-8C-2300-Monza-1932-asta-32-768x576.jpgAlfa-Romeo-8C-2300-Monza-1932-asta-67-768x576.jpgAlfa-Romeo-8C-2300-Monza-1932-asta-44-768x576.jpg
For the front, I changed the mounting post from a plastic stud to an aluminium post, made an aluminium bezel complete with clamp, added the wire all the way to the buld (the bulb and wire can be seen thru the lens), reproduced the blue tape glued to the lens and added all missing bolts. For now, I used blue masking tape to do the criss cross but I'm waiting for custom made decals, I'll see which is best.20230405_140554.jpg20230405_140814.jpg20230405_140627.jpg20230405_093709.jpg
Finished the day by installing the exhaust and painting the steering wheel (don't like the color I choosed for the steering, I'll have to redo it).
20230405_173752.jpg20230405_173911.jpgAlfa-Romeo-8C-2300-Monza-1932-asta-71-768x576.jpg
The kit's tail lights View attachment 367562
The ref car tail lights View attachment 367577View attachment 367578
I had to redo the mounting post with the mounting clamp, redid the bezel in aluminium and added the wire with ties.View attachment 367580View attachment 367579
The kit's front lights View attachment 367571
The ref car's View attachment 367575View attachment 367585View attachment 367576
For the front, I changed the mounting post from a plastic stud to an aluminium post, made an aluminium bezel complete with clamp, added the wire all the way to the buld (the bulb and wire can be seen thru the lens), reproduced the blue tape glued to the lens and added all missing bolts. For now, I used blue masking tape to do the criss cross but I'm waiting for custom made decals, I'll see which is best.View attachment 367582View attachment 367587View attachment 367581View attachment 367583
View attachment 367589View attachment 367594View attachment 367595
Same wonderful work as before ! Just amazing !
My admiration is growing each time you post new photo's.
Congrats on your latest attempts at lock-wiring......except the bias is wrong sided, but otherwise is more convincing than simple straight lines.
