Hello dockattner,
Sorry for the delay in getting back with you my good man on your Deck Planking questions you had for me. Prior to me commencing the Deck Planking, I actually gave a lot of thought on how I wanted the Deck Planks to appear on my model after some researching. After I got the copies of the actual blue prints of the RC from the National Maritime Museum, Greenwich, London, I was able to confirm the actual width of the Deck Planks. The Royal Carolines Deck Planks measure approximately 5.75" inches Wide. Deck Planks of this width were usually (
but not always) attached with a single Treenail or a threaded Lag type of Bolt & then a Single Dowel was used to cover the Treenail Head. I have a Book-- Rees's Naval Architecture 1819-20 that also discusses the use of Treenails and confirms this and the information previously posted by Jimsky.
The Longest Plank for the Cabin Deck was just under 21' long and no Butt Joints were needed or required for this length. Planks Longer than 22' feet in Length were normally not used in this length or for this Deck application. Some other reasons (
not limited to) Butt joints
NOT being used was to minimize Splinting, wood checks and to help the ease of caulking to prevent water leakage and it also helped to create a uniform surface for sailor usage of the Deck.
At the end of the day, I decided to go this route based on what Literature & research I have done/read and I have yet to see any other Royal Caroline be done this way.
By no means Do I consider this the Final say because without actual drawings or prints of the Original Royal Caroline Deck Treenail layout, one can only speculate as to what was actually done originally but at the end of the day, I like the appearance.
Hope this helps --Rick
