1930 Bentley Blower by Aifix 1/12 build log [COMPLETED BUILD]
A bit like on the Alfa projet, the working parts will be visible from under by removing the oil pan. The head the it's drive gears should be visible by removing the head cover. Since the reference car is brand new, I might display the model in a being assembled stage, I haven't decided yet.
I've pretty much finished the brake linkage modeling, l should be ready to send these parts to resin print next week. 20230706_223937.jpg20230706_221156.jpg
View attachment 20230706_222859.mp4
I decided to tackle the steering box. To my 'not so big surprise', the steering wheel is not linked to the wheels on this kit, in other words, the front wheels won't steer by turning the steering wheel. That's not acceptable. So I decided to add a worm gear combo to fix this.
Here's what the kit provides
what's surprising is that there seems to be a space already moulded in to receive a worm gear. Could it be that in the past, the kit provided something for this?
So here's what I wanted to do
and after final fitting
and the result
View attachment 20230706_214017.mp4
I should be ready to start the frame rail modifications soon and should have a glued up frame shortly.
Did some more work these ladt few days. Added the front brake shoes with spring
Modified the rear shoes to simulate the double shoe setup (I missed that one). The real setup calls for one pair of shoes actuated by the foot pedal and one pair actuated by the hand brake.
Started tinkering with the gear box and drive shaft.
I 3d modeled the wire wheels.
it's not 100% accurate but all I needed was to create the hole patterns on the rim so I could design the drill jig.The kit's wheel are not accurate, they have 1 set of holes on the outside rime and 2 sets on the center portion.
In reality, it's 1 set on the outside rim, 1 set in the center and 1 set on the inside rim. The hubs will be printed.
And the jig
I'm still not happy with the brake drums I printed. New one are being printed as I write this.
I also added pedal pads with the Bentley 'B' on thems. And the clutch fork.
That's pretty much it for now.
And the jig
Dear François
you are doing wonderful work on this Bentley , thanks for the explanation and the movies
Hallo my friend,
I got yesterday a newsletter from a well known car-dealer for historic cars - so I was thinking about your building log
- so if you have the money you could buy a Bentley 4,5 Ltr Le Mans Special - not completely historical correct, but it is a great Bentley and relatively "cheap" - and "cheap" is relative
I love this car - but ....... I have a Horex
Hello all, it's been a while.
2 big steps were achived today. I finally assembled the ladder frame with a mix on kit parts and newly printed parts. Everything went together well.
next, I test printed the front portion of the body. I wanted to see if the parts were printable and how they would fit together. Again, I'm very happy with the result. Even if preliminary, it is promissing Althougt I'm not sure l'll ever make it in wood.
Here the newly completed 3d body on the frame
and as a reminder, the real thing
Next, I'll do some test fitting of the aluminium sheets on the body.
Still working on the second body prototype. Added the aluminium sheets to the front portion and tried my hand at covering it with the faux leather I found. Not to bad for a first try. I still have to work on the flatness of the assembly so that the seams aren't as visible. Not sure about my fabric choice. The ref car look a bit more shiny.20230722_211758.jpg20230722_211836.jpg20230722_214528.jpg20230722_214544.jpg20230722_214623.jpgBlower Car Zero - 5.jpg
Great body work - I like the aluminium and leather finish very much Thumbsup
- very accurate work
The original car is also a museum display! From memory, period Weymann body cars looked a little flat/dull. A little wax will bring up the shine, but I think your test scuttle looks great at scale.
After several unsuccessful tries at removing the airfix chrome, I finally found the right product. It's ferric chloride, and this stuff is nasty. Gloves, goggles and a mask are a must. But after about 30 to 60 sec , the chrome is off and about another 2min to remove the copper. And yes, there is copper under the airfix chrome because unlike other kits, and despite what others may say, the chromed parts on the airfix bentley are actually chrome, not paint, and not an aluminium deposit. The process is similar to chroming a metal part except that the copper layer is applied via an electroless process since plastic is not conductive. Once the copper is there, the chrome can be applied thru a normal electro plating process. This producess a very hard chrome which is why it can not be scrapped or sanded off without serious damage to the part itself.
I tested Revell's chrome paint on the gear shifter and, althought very pricey at around 35$ canadian, the result is very surprising and extremely simple. No black primer, no clear. Just spray and let dry for 48 hrs. I'll never fuss with Alclad products again.
Here's the shifter before
and after the chrome paint.
I've also completed the body's framework. I printed an assembly jig which made assembling all 20 parts a breeze and everything came out straight.
I then added the aluminium sheeting
It's now ready to wrap. I tested several materials but didn't like the look of them or the ease of application. So I decided to use latex instead. It's very thin (about .005" which gives 1/16" scaled up and that's about right) and very strenchy. I couldn't find a latex sheet so I decided to use a large size party balloon. I'll start by wrapping the frame with a thin layer of either felt or foam to give the latex a soft backing. The real car seems to have some type of padding under the skin. Once the small end of the balloon is cut off, I'm left with a dome which can be stretched over the frame and glued very carefully. The latex finish is a bit too dull but I can use a latex shinning liquid to give it a nice sheen. Well that's the plan, now I have to make it work.
My frame next to the latex balloon
And a real coverded frame
Hi, Francois.
Nothing less than impressed with your efforts and brilliant photo's, thank you?
What is your source for the real car photo's please.
Thank you pugwash, my ref car is the car 'zero' of the new continuation series recently built by Bentley. Back in the late 20's/early 30's, the Bentley blower was being constantly modified so Bentley had to choose what moment in time they would base the new car on. They decided on the 1930 Lemans race, and on sir Tim Birkin's blown car. The original still exist, it was completetly dismantle, 3d scanned and, in the process, restored.
Armed with all this data, they built the prototype car 'zero', first on a 12 car series.
You can find many different articles on this project on the web. The photos are all the same and scare.
Completed the gearbox today. I'm not 100% satisfied with the shifter gate. Right now, it's painted to look like brass but I might try and make a real brass one. Espacialy since the gate and shifter are the only 2 things from the gearbox assy that are visible once the model is complet.
View attachment 20230731_215821.mp4
l also printed a holding fixture to hold both bulkheads in relation while I glue some brackets in place.
Here's the design (hi-lighted in blue)
And the fixture in use
I'm still scratching my head as to how l'll glue the latex covering on the body, it's getting clearer but I'm not quite there yet. I do know that I'll probably glue a thin felt between the body and the latex to give a little more volume and roundness to the latex.
