A Dutch Fluyt in shell first, reconstructing the "Ghost ship" scale 1:36
The build up of the stern frames is comparable to the work on the bow. We do again have three reference surfaces being the stern post rabbet, the "scheerstrook" and the shape of the floor section. The shape of the stern section is totaly different from the bow and much more complex.
To setup the battens to shape the stern section I first created a futtock (oplang) which creates the outer edge of the hull shape at the stern. This oplang is rather long and fitted on the already installed floor planking and supported by the v shaped floor timber called "zogstuk".
This oplang is nearly straight except for the curvature in the end to reach the scheerstrook. You can see this shape here in different angles on the Tallinn wreck.
The long straight oplang is visbile in another wreck of a fluyt called the Jutholmen wreck. The Jutholmen wreck is a small fluyt of which only the lower hull remain making the construction much better visible.
You can see such a futtock at the arrow. The stern is fallen apart and the sternpost is laying flat on the seabed behind the hull.
Also the set up of futtocks is different. In the bow the futtocks are simply placed on the horizontal floors which run up into the bow section enabled by its flat construction. In the stern the construction is different due to it v shaped floor.
Looking at the Jutholmen wreck from the top you see that the oplangen/futtocks in the sides of the ship are more or less parallel to each other and in the stern section they diverge from each other rotating aroung the foot of the sternpost.
Another wreck I looked at to get a better picture of the stern construction is the Alvsnabbenvraket which is of a Dutch type ship of the 1700's probably a smack, kof or galjoot which had comparable stern shapes.
This wreck has lost its ceiling planks on one side which enables you to see the construction of the inner framing a little better.
Here you can see that the stern is build up from vertically place oplangen/futtocks only. There are no horizontally placed supports like with the floors in the bow construction.
As there is ample space in the stern not all these oplangen will start at the bottom but a lot will be fitted only to the planking higher up in the hull construction.
Unfortunately this we can't also see in this wreck.
Also we see on this wreck and on the Tallinn wreck that on both sides of the stern post also oplangen were fitted directly against the stern post.
The space between the two oplangen on both sides of the sternpost was filled with a simple plank against the inside of the stern post which can be clearly seen on the Tallinn wreck.
The result of all this is the start of the oplangen in the stern.
And some pictures of the hull outside in daylight.
Wow! This is fantastic. Very impressive Maarten. Cheers Grant
Wow Maarten. It starts to look like a real ship. The curves are great.
Isn't it winter where you live? The landscaping suggests otherwise...
It certainly is winter, but not all type of trees loose their leaves and the hard winters with lots of snow and ice is something of of 30-40 years ago and getting scarce now. Untill now this winter only 1 week of some mild frost. Climate change is certainly something we see happening.
It's looking great. In the beginning I did not thought that you can use the original method in this scale. I was wrong.
The only thing I would change is the baseboard of your jig. Iwould screw two vertical plywood timbers under your board to avoid the torsion which is visible in the pictures.
Nice to see how the stern is getting her shape, Maarten. And the last outside pictures shows her beautiful lines.
The pictures of the scans are still impressive in what details they show.
Hi Maarten, Congratulations great job of real carpentry , I ask : is it the photo that distorts the alignment? Thank you.Frank
it's a unique work
Hi Christian,
This is certainly something I will do, but first I take here out of the jig to fair the outside frames. Was thinking about aluminium square tube but multiplex will also be an option.
The sun was shining today so some corse sanding of the inside of the hull.
For this I use the Proxxon angled grinder with a sanding disc.
Works perfectly and fast.
The high speed gives some discoloration which can be easily sanded away afterwards.
The last oplangen in the stern are fitted.
Above the short ones on both sides of the sternpost the loading doors will be cut afterwards.
After this I will fit the top wale above the scheerstrook.
Some modern machining in a old fashion build is no problem at all, Maarten.:)
Hello Maarten,
Maybe the book " Het model van het Fregat "Geelvinck' " can help you with the technic of building shell first.
It's about another type of vessel but it shows how building shell first looks like.
Good luck
Hans Peters
Hoorn
Sorry for the lately question, Hans. Are there propper pans within this book to build a modelship from it?
Dear Marten!
Thanks you very much for this journey into Dutch shipbuilding High Tech. I binch read your threat this night and I am astonished about your great work and courage to see earlier errors and undo them. I did learn a lot on Dutch shipbuilding by this text and a plenty on working practice on the Dutch ship yards.
btw
When I looked on the topview I associated immediatly an old Samsonite suitcase with this hull shape...
