- Dec 1, 2016
So do you plan to correct the errors in CAD or leave the as per the original plans?
there are two types of drawings going on what you are looking at is the original drawing done by Harold Hahn done on tissue paper. These drawings were copied and a master made that all others were then reproduced from. A + or - was not that big of a concern as the drawings gave the model builder a frame work to build in. As the model is being built the builder will tweak and fit all the parts
Later on Harold switched from using tissue paper to mylar which was far more stable and gave sharper pen lines.
the way Harold drew his plans can be seen here, a master plan was drawn this is the original master drawings for the Oliver Cromwell
zooming in you see the graph
pieces of mylar were laid over the graph and each frame was drawn
these are drawings done for model building and once the original drawings are done a master is made and from that master blue print copies are made for reproduction.
NOW
what is being done with the Alfred stern is drawings are done for "machine work" so all these small imperfections are worked out and precise X,Y,Z are set so the machine knows where everything is, where it starts and where it ends. This is a totally different approach to drawing than the originals done by Harold.
everything comes down to numbers a machine sees 1.25600 <0 1.4482 . 90 there is no mistake, no sort of close it is exactly what it says.
so to answer the question what started out as a hand drawn alfred stern will end up as an exact machine drawing
