Batavia VOC 1:72 Kolderstok by RobertD
The Chamfering tool , it works okay , but since the hull planks are in Oak it is hard to see because of the density of the wood , in hindsight I might give it a shot with other timbers .
Thank you for your response. I need to assemble that little gadget and try it out.
Jan
Dear Robert. You must be very pleased at the way your Batavia is turning out. It is a beautiful ship to build and yours is right up with the best ones I have seen. The rudder assembly looks perfect!
Thank you Heinrich , a great ship to build , I have been working on it everyday in my Man’s Cave whilst the Admiral is overseas to visit her grandchildren , I have used tiny nails to temporary secure the planks of Oak on the frames whilst the glue sets , that Oak is so dense to even get a nail in is tough !hope you had a nice break in SA , cheers Rob
working on the bow , gave a white under water coat , initially tried a spray paint , that was not so successful so used an acrylic brush source and a decent masking tape , of course there are always issues , I refer a lot to Nicolaes Witsen , ship building in the Dutch golden age for ideas , for instance I will use a lot of gold paint instead of yellow ( yes they used that as well during that time ) I black painted the guns , on the merchant vessels in that time hardly copper that was reserved for the Navy
Beautiful Robert. That oak hull looks wonderful and offsets the colors beautifully.
Nice work Robert! Wow, you do go through your modelling at a blistering pace? Very impressive Thumbsup
Thanks Heinrich , the supposed to fabricate the Rudder hinges with the brass supplied would be a disaster with drilling holes and soldering hence I ordered
Rudder Hinge – Brass – 1/8″ X 43/64″ (3x17mm)​
No soldering needed , also an extra hole can be drilled easily , the nails in the kit are robust so used smaller nails from a different source in the wales , to be more authentic
Dear Robert. Can you please tell me where you sourced those hinges from? I think that is also the route I would like to follow on the Willem Barentsz.
Good morning Robert. I love it. The oak with the white below the waterline is beautiful. You are owning this. Cheers Grant
Progress so far , touched up the paintwork , had too! in natural light ,it shows the blemishes , I have from other sources hinges for the Gun Ports , they are non metal , I think they are pretty neat , working on the stern and aft part , the paint clolor , the admiral liked this better! of course I rectify and clean up as I go along ,
She has teeth! From what I can remember those 22 cannons add a bit of weight to the model!
She’s coming along nicely!
Luckily for you she's not one of those 100-gun behemoths.
