Belle Poule 1780 1:72 - Sail and Sail Model by zoly99sask
Yes - Very clean and accurate work
In the first view, it is somehow uncommon to work on a "waterline"-model - but it is looking like a very clever idea
BTW: I am using for such work (paper on wood) a rubber-gum glue - I prefer "Fixo-Gum" from Marabu - you can remove the paper easily and the rest of glue with rub with the fingertip
I really like this way of inserting gun ports and gun port linings. As the linings are pre-cut you know they are correct, so if something doesn't fit you can make the required adjustment. This way all ports are 100% aligned, same size and symmetrical. Nice!
Here are more choices:
After finishing up the gunport lining I had another round of sanding inside and outside, meanwhile, I built the next part of the jig and placed the upper deck upside down on the top of the jig to build the lower level of the hull.
8FAF7995-B953-4096-B3AD-58C77450B140.jpegB842D44E-D3E0-43B6-9FCA-DA83804BB433.jpeg721A579F-9A45-4972-84A6-F7D790B5E541.jpeg
