Bluejacket Tug Sequin 1/4” scale
I am a fan of the contrasting wood color tone.
Was there much difficulty in bending the walnut? Did you soak in water for a day first?
Love the chicken and the black smoke stack.
Yup, the Mahogany was a tough bend. I made a outline form of the stern, soaked the Mahogany in very hot water, finger bend it to test the pliability and repeated the procedure until I could bend it around my “form/jig”. Once the Mahogany was attached to the “form/jig” I placed it in a bowl of hot water and let it soak overnight.
Sounds like a lot of work, but the end result was a very nice curved piece that fit.
Jan
Rainy day, excuse to work in the boatyard:
Making progress on the deck. Glued in forty two frameheads. Found another of those pesky errors. While sanding the hull after planking, I inadvertently broke off most of the vertical posts that were added to the frames prior to the frame and keel assembling. I cut and glued in some new ones before I stared the bulwark planking. Unfortunately they were too short.
I replaced them with new Mahogany pieces while in the process of adding all the frameheads. Those will be a reminder when I look at the build in the future.
Next on the agenda was the building the stern grating.
This part was fun but time consuming. After couple of false starts I managed to get it done.
Last on the agenda for today was make a jig to bend the bulwark cleat, two 1/16" square pieces of Mahogany 25" long.
I used the left over cutout that the deck was attached to as a template, traced the curve of the deck onto a piece of 1 X 4" board, added some dowels and viola, I was in business.
In the background of the picture you can see the stern grating being glued in place.
Jan
The stern gratings will blend in beautifully with the mahogany - yet retain its own distinctive character. That is the beauty of working with contrasting woods.
The Hull:
A bit more progress. The bulwark cleats have been installed, the Port side is complete with the cap rail and rubbing strakes having been added. The cap rail was a bit tricky, I broke several of the 1/16 X 1/8 inch Mahogany strips trying to bend the them edgewise to follow the curve of the bow. My final process was to steam the pieces, start a gradual bend, let them dry on my "jig", steam them again and continue the gradual bend. I took several days before I was happy with the outcome.
The Starboard pieces are in the "jig" drying.
So far everything for build appears to be in the right place.
The overlay I made has been a great help. It's been easier to use to spot items on the deck than trying to scale them from the plans.
Jan
Another rain day, Thunderstorm cells moving through. Good day to work in the boatyard:
Managed to finish the cap rails and rubbing strakes on the S’board side. Spent a little time masking the areas that will not be painted.
I looked at the hull and thought “maybe a deck gun, a conning tower, diving planes and couple of torpedo tubes”. :p
Jan
Hi Jan. Now you are talking. I so wish there was a truly detailed kit available of a submarine. But back to business. Your hull looks beautiful and very very neat. Well done!
Another wet day and some time in the boatyard:
A little more work on the hull getting the final paint scheme in place.
I have to add the black water stripe between the red and green colors, add the propeller and rudder to complete this part of the build.
Jan
Love the colour scheme Jan! Its the same as the Haarlem's! The maroon and black combination is such a classy one!
Jan
Jan
A very beautiful job that is already achieving some very impressive achievements
The hull:
I had some fun cobbling together the ice chest.
It’s built from bits and pieces that were left over.
The hull is now complete. I‘ve ordered a 95mm lifeboat kit, the block of wood supplied in the kit was to be carved into a lifeboat. My earlier experience with carving was a disaster, hence the kit order.
I’m pleased with combination of colors on the hull. When I started the build I had color scheme in mind and this result is very close.
Jan
Final Assembly:
I had time today add the deckhouse to the hull, set and rig the masts and add bits and pieces to the deck.
Last construction will be the lifeboat kit, which hopefully arrives next week. I also need to go to the Lumberyard to get material to build a baseboard.
Jan
