Good work Henk! She is coming together very nicely!
Wire on a piece of brass with the thickness of the bolts that I had received from Peter, bent and tightened
and twisted in 2 turns
Dead eyes of 5 and 4 mm used with Peter's bolts of 0.8 mm
Piece of wire slightly bent and the wire with the deadeye on it bent for the other side
Right above the Deadeye of QY
View attachment 375857View attachment 375858
Step by step and with a lot of practice you made them look very nice, Henk.Put a bolt through it and tighten the nuts, all this on a black cloth.
Everything made matte black on the irons that are turned on a needle in my vices and the production can be started.
This is very easy
I don't blacken dead eyes, I still have trouble painting beautiful wood.
Regards
Henk
Thanks, Dean
I like this method Henk.Put a bolt through it and tighten the nuts, all this on a black cloth.
This is very easy
Regards
Henk
I watched a lot of Peter's construction, and learned a lot from it.I like this method Henk.
2 Roll 0.35 mm Black Florists Wire Floral .. https://amzn.eu/d/iSGD33Vlready black or, however, I don't know if this can be found in the US
This wire in my post was perfect for this and is already black or, however, I don't know if this can be found in the US
Thanks gentlemen, I do have some 0.5mm and 0.7mm soft black coated beading wire I will experiment with.2 Roll 0.35 mm Black Florists Wire Floral ..
You have a great adaptation of the wench system, looks more like the real thing in the photos than mine.Sprockets adapted to the winch machinery, now touching the other sprocket
Chain placed on the windlass, a bit older
Belaying pins painted and added
And finally Dean's anchors placed
Foredeck is ready
View attachment 388930View attachment 388931
A crowded fore deck with nice detail, Henk. Like the anchors weathered a bit by the sea water. That shows your painting skills again.Sprockets adapted to the winch machinery, now touching the other sprocket
Foredeck is ready
Thanks Peter,Like the anchors weathered a bit by the sea water
The journey is not over yet Johan, I expect a lot of headwind and strong currents at the masts and the riggingIt's been quite the journey Henk,
Thanks Shotagreat adaptation of the wench system
suburbanshipmodeler.com
I agree with you there Henk, your journey is not over yet.The journey is not over yet Johan, I expect a lot of headwind and strong currents at the masts and the rigging
I am sure you will make lots of photos...and we will be one of those lucky ones to see them here, on SOS!September 30th I go to the National Maritime Museum in Amsterdam with Peter and Johan
That's where national and international ship model builders meet that day
3x BN in a row in a special environment
