- Sep 3, 2021
No, red is Amsterdam green, so you're good to go.I thought green was for go and red was for stop!
I personally experienced this anomaly. Plus, one way streets are only a suggestion.No, red is Amsterdam green, so you're good to go.
I started with the flags loaded on SOS by @TechTrek. https://shipsofscale.com/sosforums/threads/bluenose-flag-set.6597/Nice flag Jeff. Can you share the file?
Thanks!I started with the flags loaded on SOS by @TechTrek. https://shipsofscale.com/sosforums/threads/bluenose-flag-set.6597/
I took his design and change the maple leaves to green, made a foldable version and slightly reduced the flag size. See attached.
Good morning Jeff. Cool Flag. Cheers GrantI found the correct Canadian flag as a PDF for the Bluenose online and made a couple of modifications to it. My (brief) research has the leaves on the flag at the time being green as opposed to red (changed to red in 1957), so I modified them to be green. I also sized the flag to be more in line with the model. I made a couple of variations and printed them on T-Shirt transfer paper with an inkjet printer. Using an iron, I transfer the flags to a thin handkerchief. I settled on the back-to-back version of the flag and glued the 2 sides together with white glue with the flag halyard sandwiched between the sides. Once dry the flag was raised and belayed.
View attachment 395388View attachment 395389
I have taken the final images of the ship and will post them soon.
Good morning Jeff. There is no applause emoji and this deserves some! Beautiful, you will proudly display this Bluenose. Lovely pictures. Congratulations. Cheers GrantAnd the final detail images:
View attachment 395663View attachment 395664View attachment 395665View attachment 395666View attachment 395667View attachment 395668View attachment 395669View attachment 395670View attachment 395671View attachment 395672View attachment 395673View attachment 395674View attachment 395675View attachment 395676View attachment 395677
Hi Jeff, I Like this very much, it has lots of nice touches and has your stamp on it. Well done.And the final detail images:
