Thank you for the great review Heinrich. I would like to give an opinion on the name plate issue that has been discussed. I have built many paper models and I believe the name can be fixed easy by printing the name on paper. Then the strip with letters can be cut out and glued around the back of the boat. It will follow the curves nicely. Paper with wood glue applied when dried has the properties and the look of wood. It then can be finished with a matt coating. Would look more appropriate, realistic and nicely scaled than a name plate or photo etch and is a cheap fix. Different early versions of the name can be printed on one sheet of paper for a builder to choose.Dear Gents - I am back so let us look at the stern issue.
FACT: The brass name plate is historically incorrect.
This picture indicates two locations:
The White indicates the location of the original Bluenose's name.
The Yellow indicates the location of the Bluenose II replica's name.
The original Bluenose. The lettering is in white and contains only the words BLUENOSE, the MASONIC SYMBOL & LUNENBERG all in one line. (The NS for Nova Scotia is omitted).
Bluenose II (courtesy of Halifaxphoto). The lettering is in gold and contains the words BLUENOSE II with LUNENBURG, N.S. underneath.
I think I speak for everyone if I say we stick to the original option with white lettering.
Dave Lester - who originally explored the connection between the Masons and Bluenose - built the Model Shipways Bluenose in 1:64 scale here on SOS. Dave is unfortunately no longer a member of SOS - neither do I know where to find him to obtain permission to use his photo. However, since the picture is still available on SOS, I am sure that it will be OK seeing that we are using it for a good cause here.
This is David's model of the Bluenose with the original lettering and masonic symbol. (Photograph by David Lester)
This is the lettering that David created. (Photograph by David Lester)
On the picture this looks good, but he did mention that the letters were very small. Obviously in 1:72 scale, they are even going to be smaller.
Is everyone happy with this?
, Peter. Thank you very much for the support and welcome onboard Bluenose!
