- Dec 1, 2016
oh the zen of modeling a break from researching, time to focus and cut some wood
each and every step of model building requires some pre planning, you can fly by the seat of your pants and correct as you go, some plan every move every cut. I am someplace in between the two. This is what i needed to end up with
and here is how I planned it, first i found center on each side of the pit, the red X now i took a measurement from the drawings and from the centers measured out in each direction. This gave me the point of the corner braces and each one is exactly in the same place. If your going full build the ends are morticed into the main beams. Here you can see i took the short cut and butted the ends to the beams.
the two ends are flat on the top you will see why later in the build. I realized right from the start you can not place the sides into the pit because the ends are angled, so they have to slide down from the top. Keeping everything in place proved to be difficult so i glued these ends in place.
