     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
This can be only answered when we take a look at the cross section where either the frame with all parts and the location of the wales are shownIf you install them from the outside though, won’t they leave a larger hole to fill from the countersunk head? Or will they all be covered by the wales?
I have the feeling that the screw hole will be afterwards covered by the lowest timber of the wales
When the screw heads are inside - no problem, because you can install than all wales -> you only have to shorten the screws in such a way, that the peak is not looking out of the frameI think that you will need to have the hull "fully assembled " for the whale installation or if you want to add a few planks.
@Uwek how will you unscrew the screw if the wale is covering the screw head ?
I need to go and take a good look to my kit drawings to understand if what I am writing is correct or we really need to use "something" that can be pulled out from either side. Like brass wire suggested by Tom on the 3D drawings. Or Pins or nails with/without their heads.
Daniel
When I asked the question of how you would have removed the screws I did not take into consideration the possibility that you proposed, I thought that the screws were inserted laterally to the rib that is moved by 180 ° with respect to the insertion of your screw therefore impossible to remove for the presence of the other ribs. Thanks for enlightening meAn update on the temporarily joining the upper section of the rib to the lower section. I have tried out my small screw plan and the results are very promising so far. This is my first attempt, rib 31, a large center rib made up of three individual ribs. This is the bottom section
This is the upper section that I am trying to fit temporarily but firmly
This is how they dry fit
View attachment 272314View attachment 272321
Once dry fit, I clamped and drilled a small hole to engage both sections
Then screwed the sections together
View attachment 272324View attachment 272326
Although difficult to see, the small phillips head screw is in place, with the head on the inboard side of the rib. Could go the other way I suppose but as I think the tendency will be for the upper section to want to fold inwards, I thought that having the head of the screw inboard gave it most strength. Knucklehead engineering on my part I suppose. Anyway, as the screw is 10mm long, it does protrude through the other side but can be cut off with a good set of nippers. Once the screw is installed, this joint is very secure and I am happy with the result. I will complete this rib and work on the rest of the large 3x ribs before attempting to do this on the narrower 2x ribs. I think they will be more challenging but am hopeful that the result will be successful.
