Greetings .Hello everyone, hello Pavel, these are my boards, the details of the joints with the nailing are all misaligned. How you do it? A manufacturing error? Can you get the right ones?
Thanks Pavel, then it would be appropriate to update the instructions because as you can see from the photo there is no trace of this piece. If you can also tell me about part 63.
Nothing, maybe it's just to keep all the support in placeRight or wrong I glued the assembly as shown on the build plan that came with the kit.
Other than add more stability to the assembly what does that part #44 do.
This is exactly how everything is conceived in the set, which is made of walnut. Once you've sanded all the boards and oiled them, the two walnut planks will start to stand out in color. This effect is implemented on all four decksWho among you have purchased the optional walnut option? I have it with Kit 47 and am confused as I begin to lay the deck planking.
Below is the main deck. Please note the walnut strips on the port and starboard sides of the grate. Those are the only supplied planks for that deck which are walnut. The remainder of the deck planks are not walnut. I glued the walnut planks in place but upon realizing the mismatch have stopped and not glued any others in place, The five short pieces seen here are not glued and are only in the picture to illustrate the color of all the remaining deck planks.
The photo below is a temporary assembly to illustrate the color mismatch in the deck planking meant to go by the bowsprit.
Do any of you with the walnut option have a similar situation?
Respectfully,
John
This is how everything will look on your ship.Who among you have purchased the optional walnut option? I have it with Kit 47 and am confused as I begin to lay the deck planking.
Respectfully,
John
Thanks for the kind words about our work.Thank you for that information, Pavel. I clearly see the shade emphasis in these photos. As many times as I have looked at the collection of photos I have never noticed that feature. i Am pleased that you pointed it out. The ship is going together well. The instructions are clear and the videos are superb. You may well be setting a new trend that will increasingly be expected of other kit designers.
Number - PN 3362 this oil is used as a top coat, applied in three coats with intermediate sanding with abrasive number - 320. For painting decks I usually use lighter colors, this is number - 705. All other colors are used for the outer sides of the ship. PN 1\900 is a black patina, used to create the effect of old wood, and is applied at the very beginning. Color combinations must be selected independently on the samples and guided by your taste. The very technique of applying color coating and oil can be viewed on the YouTube channels below. There are also subtitles. The main thing in this process is applying both patinas and tones in very small quantities and in many passes, and a professional skill will appear only with some practiceHi Pavel, the kit is great, despite some mistakes with inserting badly lasered plates and missing directions in the manual. I also bought the paint kit. Since there is no explanation, is it possible to have an explanation of the various codes and how they are used? Thank you, also for everything you do despite the difficulties known to all
Thanks Pavel, could you tell me, also as advice based on your experience, how and where to use the colors of the other issues? I use an Infinity CR Plus airbrush, what number of needles do you recommend to use? thansNumber - PN 3362 this oil is used as a top coat, applied in three coats with intermediate sanding with abrasive number - 320. For painting decks I usually use lighter colors, this is number - 705. All other colors are used for the outer sides of the ship. PN 1\900 is a black patina, used to create the effect of old wood, and is applied at the very beginning. Color combinations must be selected independently on the samples and guided by your taste. The very technique of applying color coating and oil can be viewed on the YouTube channels below. There are also subtitles. The main thing in this process is applying both patinas and tones in very small quantities and in many passes, and a professional skill will appear only with some practice![]()
The instructions show one of the possible ways that is used to bend the boards of the ship's side plating. And it is shown how you can make the necessary equipment for this operation. For example, I use a different method, which is shown in video instruction # 39. Plate number 43 is not in the set, it is an arbitrary number, and is shown only as an example of making a tool.Pavel, the manual shows a piece to be built using parts from plate 43 which is not in the kit. Why? How can it be done?
