Started with dry-fitting the bulkheads, lower deck, quarterdeck and forecastle deck.
Fits snuggly, so I moved on to gluing the parts together with the help of the deck to line the bulkheads up correctly. Added the filler blocks at the bow, these aren't very large so I decided to do some initial rough sanding before putting on additional balsa blocks. That is, if I can find balsa wood in my town. Seems to be mostly a hobby material and not available in any of the large store chains here. Maybe pine wood works too?
Started with sanding one side, then moving on to the other. The skeleton is made of this heavy and sturdy feeling fiber wood. Pretty easy to sand down, but damn it eats through sand paper like no other wood I've worked with. At least there shouldn't be any issues with the skeleton bending with this material.
I fastened some sand paper onto this ruler to sand the length of the hull and used these foam blocks to get around the bow and stern. For the keel I used a file
That was the rough sanding, will go at it again when I have placed the filler blocks. I went pretty aggressively with tapering the keel area for the rabbet line, figuring it won't hurt. After all, I need to fit the first planking which is 1,5 mm thick and the second layer with 1 mm on both sides of the keel which itself is only 5 mm in thickness.
I went on with placing the main deck. It is split in two halves which Amati suggests planking before placing on the ship. Though I want to have a center (king's?) plank over the gap between the two halves, so decided to place it first and do the planking after. Ran into this issue which you can see in the below picture. A long stretch of the center of the main deck is not supported and is quite wobbly:
Fixed that with the leftover parts of the sheet the bulkheads came with and now it does not wobble anywhere:
Glued and clamped down the main deck and now it is ready for planking:
