H.M.S. Fly by Amati 1:65 - Build log by Jcob
Dear Jacob, I have also only discovered your build log now. You are doing a fine job on the Fly - I am very pleased that you also enjoy the planking process. To me that is also the most satisfying part. Yours look so good, that it is almost a pity that the hull had to be painted!
Hey Heinrich, thanks a lot! Yeah, perhaps I should've used some wood filler before painting below the waterline. But still pretty happy with the result. Soon it will be time for quarterdeck and forecastle planking, looking forward to it.
Best, Jacob
Hello all,
Been distracted with some other stuff recently so work on Fly has been slow. My first build, the HMY Britannia was taking up space in front of the window that I want for new plants with spring around the corner. Had some balsa wood laying around that I formed to the hull shape and painted light blue to simulate water. Result was light and compact so I could hang it on the wall with command strips:
Back to the Fly, went all the way with painting the kit supplied metal side windows and placing the brass decorations around the hull:
But the windows felt flat and either the layers of paint paint or underlying metal piece had an uneven surface that stands out when light hits it from the side. And the brass decorations shine too, distracting from the rest. I realised too late I probably should've painted the brass in ochre yellow, but I got inspired by Olha Batchvarov's Pegasus build on her youtube channel where she painted the decorations in turn inspired by the FFM books:
So I'm trying to find a method that will give a shadow effect using two colours and then practise on bits of wood, testing different things. Much will be training my hand skill so I will be able to make round curves, tests look like this:
The side windows I replaced with balsa wood. Had some thin sheets of balsa laying around, put two together in opposing grain directions so it wouldn't rip later, then used the kit metal window as the template for its outer shape.
Marked the outlines and used a small file to sand it down, used toothpicks for the window grilles:
And now working on the second one:
Also the kit supplied decorations for the stern windows are a bit small compared to the other laser cut wooden pieces. Here you see the mismatch:
Glued a thin piece of balsa wood to it to try to use that as a transition between the two different scales. Hopefully it won't look too out of place in the end.
Will be a lot of practice and planning to paint the outside decorations so I will give you an update when I've made some progress there. Seeya later!
//Jacob
A very good and innovative approach Jacob. Your scratch-built windows are a definite improvement over the kit-supplied ones.
Thank you Heinrich, I tested different things to see what works and really like the end result, so it was worth putting time into :).
very good and accurate work on the sidebadges - looking very good
Hello all,
I got this HMS Fly kit in the mail a couple days ago. I started looking around after references and found plenty of good build logs on this and other forums as well as some books and original plans that will all be helpful for this build.
Some interesting info I found from the first search:
The HMS Fly was commissioned in 1776 after being built in the Sheerness Dockyard in Kent, GB. It was part of the Swan class of sloops, the 6th of a total of 25 ships ordered of this class. The original 1766 Swan class had 14 cannons and the revived plans featured an additional two gun ports which the Fly fitted with 6-pounder cannons in 1780. The Amati kit comes with 16 cannons which indicates the plans are made with the post-1780 refitting in mind. But interestingly, the kit does not include the coppering that was installed in the year before at Portsmouth. The instructions states the Fly was used mainly for convoy escort duties and dispatches, but also managed to capture two French privateers during its lifetime.
First impression of the kit is that it is overall of high quality. It comes with a large stack of instructions, mostly containing diagrams of the build.
They made an interesting choice of material for the bulkheads and false deck, some sort of 5 mm thick fiber wood. Feels sturdy to the touch so I don't mind it:
Other materials look and feel great. First planking layer is lime wood. We have walnut for the prow, keel, rudder and the second layer of planking. Deck planks are made of Tanganyika wood which will look good with just clear varnish. Other bits and pieces I'm not so sure of.
Accessories also look detailed. I decided to order the upgrade kit for the cannons, but it haven't arrived yet which is alright since they will be worked on later in the future. I was interested in spinning my own rope but I might not be so anymore after looking into how people create their own improvised ropewalks. I couldn't find ready-made ropewalks anywhere online, so we'll see about that.
I have some initial questions that I will try to answer in the beginning of the project. The first being the deck planking which Amati splits in three sections on the gun deck, which I'm not sure if this is simply to avoid planking around the three mid bulkheads that will be removed later in the build or if this is accurate. I can't find any hints from the ship's original plans but maybe there are plans/photos of other Swan class sloops out there to help me. Here you can see how Amati splits the deck in three segments:
Then there is the question of colours. Amati provided a list of what to use for this build but I haven't bought any of it yet. Gotta find out where to buy "Indian Ink" and if there are alternatives. Black and white I already have and will be using all acrylics for this build (just personal preference), so I will need to find the correct blue, yellow and red tones that aren't oil based.
Lastly, the kit comes with 16 x 1/2-pound swivel guns and the plans put 10 on the quarterdeck and 6 on the forecastle of the ship. Wikipedia also states the Fly was commissioned with 16 swivels, but I can't find anything about that in the source cited (Winfield, 2008). Winfield 2007, on the other hand talks about the swivels for the Swan class, saying they had 12; 8 quarterdeck and 4 forecastle. So I don't know what to believe here and the original plans of the Fly do not show the swivels or cannons to help me out. I haven't looked much at plans from the other similar Swan class sloops, so that might give some clarification. Here are the swivel guns shown in the instructions from Amati:
Gonna start with dry fitting the bulkheads and will see where to go from there.
/Jacob
Hallo Jacob alias @Jcob
How is your Fly-project going?
Hi Uwe, thanks! I've been pausing with the Fly lately, completed a few more things since the last post but otherwise its been pretty slow. I guess cannons are not my favourite, lots of details that don't catch my interest. Started on the East Indiaman Götheborg during the summer, so you might see a post in that old thread soon :).
