Impressive work well done
Beautiful work. I admire your skill and patienceI reinforced the frames that tended to detach in the upper part:
The stemson:
The keelson:
View attachment 261803View attachment 261804
The limber strakes:
You guessed it perfectly! They are small pieces of cardboard that help to pull out the fixing nail once the glue has set.I think, that I realized a very clever idea:
These , I guess they are some small pieces of felt: I guess you use them, that you are not damaging the wood during hamerin and fixing the wood - here the plank
and they are located in the holes for the later treenailing of the plank.
So does I interprete this correctly, that when the glue is dry and the plank is fixed, you pull out the brass nail and afterwards you implement a finsl "treenail" in the same hole?
You do a most impressive job, a great pleasure to follow your work. Well doneI reinforced the frames that tended to detach in the upper part:
The stemson:
The keelson:
The limber strakes:
you are doing wonderful work, it's looks beautiful
great progress, thank planking looks wonderful
