@rtibbs Okiedokie Ron - that is an easy one. :)
"Sieve" is translated from the Dutch word "zeeg" which translates to the vertical curvature of the hull.
The zeeg then is the U-shaped curvature of the hull planks as it sweeps sharply upwards from the middle towards the bow and stern.
Thank you for finding the passage - that made it easy to answer you! Thumbsup
Thanks Heinrich. I thought that was it but you know what happens when one assumes :))
Here in horse country we’d call that “Swayback”
Good Morning Heinrich. Your approach to model building takes me back to University and the lecture from my favorite professor. I can’t add much other than those pegs add so much color to the buildROTFROTF.
Good morning Grant! How did the rally go or is still ahead?
Thank you for the kind words. I am very happy that you find the log enjoyable and useful. In about two days' time the planking will require some hectic techniques (which I have never had to do! :eek:), so stay tuned. :)
ThumbsupGood morning Grant! How did the rally go or is still ahead?
Only in new year. Still need new tyres and a long range petrol bag.
I will do
PLANKING PROCESS: This is just a very quick update guys. I will explain in detail tomorrow or the day after tomorrow.
Starboard Side
Port Side
In total there are 14 planks that have been laid. This is not an easy ship to plank, but I am very happy so far. However, two steps down the line and I will have to do something that will scare me senseless! :eek::eek::eek: (You are right @rtibbs Ron - that thing with a knife!)
It wasn't my intention to cause you any distress Heinrich. :eek: I just gleaned the information from Piet's log and posed the question. Hopefully it will aid future builders such as myself and Grant.
I see you went ahead and added the wales at this time. Lookin' good Thumbsup
It wasn't my intention to cause you any distress Heinrich. :eek: I just gleaned the information from Piet's log and posed the question. Hopefully it will aid future builders such as myself and Jan.
Hi Ron. I was very well aware of what lies in store for me - so you did not cause any distress! :) Tomorrow I will lay down another two planks and then step back and explain everything I have done so far.
Or do we call it the SHEER:
Starboard Side
Port Side
A nice progress of the planking, after looking for the pros and cons of what first and what next.
Watching close for those 2 steps down ..........Good luck :) Heinrich
PS: Almost as dangerous as:
Oeps ..... sorry for Heinrich, you have no YouTube.
It’s the video of a/the great song of Roger Waters.
Hello Everyone
I will now take a step back and attempt to explain everything that has been done so far. This is as much of my thought process at this point as it is a build log so bear with me.
On this ship EVERYTHING is based on the position of the first 4mm plank which will also become the first wale. This plank is indicated by the yellow line on the picture below.
Photograph @pietsan Piet Sanders.
The instructions call for the installation of this plank first and from here this plank is regarded as the base plank. The instructions then list a very clear order in which the planking needs to take place from the base plank upwards on the hull.
NOTE: The three 1.5mm x 6mm planks in the green block are to be tapered to 4mm. All the other planks, including the first 1.5mm x 6 mm plank, are installed untapered.
With that first base strake laid on my model, this is what it looked like.
First Strake (4mm plank) Port Side
First Strake (4mm plank) Bow
Verification picture of Piet's build.
Next up was an untapered 6mm Plank.
Port Side: Two planks installed.
Bow Side: Two planks installed
Next up is another 4mm plank which will ultimately become the second wale.
Port Side: Three planks installed
The same three planks viewed from the bow.
So now let’s move on to what I did the last two days.
  • First off, I doubled the two 4mm planks so that they are now indeed Wale #1 and Wale #2. My reasons for doing this at this point have been discussed at length, but basically it boils down to easier access to the wales during installation.
  • Next, I glued a 6mm plank – tapered to 3mm at the bow – BELOW the first base wale. This is out of sequence with the build instructions, but I followed @pietsan Piet’s build so that I could have an exact picture at any given stage of how my build looks compared to his.
  • Now going back to planking upwards on the hull again, I laid down the next plank – a 6mm plank tapered at the bow to 4mm.
This is where I am now:
Four planks installed. Please disregard the plank sitting below the wale at this stage. This is out of sequence with the build instructions at this point. And in case you have thought - why am I only showing you the Port Side - I will do the next explanation of the layout on the Starboard Side. (Counting that plank - it would be 5 planks in total).
Starboard Side
Bow. Please do not pay attention to the unfinished edges of the planks at the bow - that will all be nicely filed and sanded down. Also note that the keel will be covering that section in its entirety.
So this is all good then??? Have a look at the picture below:
In that two mm gap, I still need to fit:
1 x 6mm Plank Tapered to 4mm
1 x 4mm Plank (Untapered)
@Dematosdg Hi Daniel. You have a very keen eye. In essence that is exactly what needs to be done Thumbsup, but there is still one 6mm plank that I can taper to the available 2mm and that will go on following the current lines. Then after that, all hell will break loose. :eek:
