Judging from the pictures, they're not tapered or rabbeted.
Hi Phil. That is a good observation. I have no idea whether they were slightly tapered on the real ships, but certainly not on the models. If you were to taper the planks on the scale at which we are building, much of the visual effect of the overlapping planks would be lost
Hello Everyone.
This really is my last update before I return to work - and let me tell you straight out - I found this to be a really difficult task to accomplish.
I wanted to finish the canopy by installing the front wall and doors. The goal at the end of this step was to have something similar to @pietsan Piet's final outcome.
Photograph: Piet Sanders
Piet's superb-looking front wall and door assembly.
Photograph: Piet Sanders. This may look like an easy assembly (and for some people it probably is, but I had my task cut out for me.
For this we will again need the laser sheet I showed you earlier.
PART C (marked with the green ticks): Already used.
Blue-marked Parts: Outer Wallposts
Yellow-marked Parts: Inner Wallposts
White-Crossed Parts: Doors.
Orange-marked Parts: Door Posts.
The instructions call for the outer wallposts (blue-marked parts) to be glued underneath the already mounted stanchion posts with the notched part facing forward towards the bow. The supplied part is too long and needs to be cut to the correct length at the TOP!
Here you van clearly see the difference between the cut-to-size outer wallpost and the one directly from the laser sheet. On the original one I had already scored the cutting line.
The outer wallpost has been glued underneath the stanchion post. The green rectangle indicates the bulwark overlap that will be cut to size and finished off later.
To make sure that I mount the wall post plumb, I fabricated a square that is small enough to fit in underneath the canopy.
With the outer wallposts mounted underneath the stanchion posts it was now time to test-fit the doors.
This is how the door comes out of the laser-cut sheet. Note that the door post still surrounds the door. Leave this as is for the time being.
Now what Piet has done is to glue two 6mm walnut strips behind both door and doorpost to ensure that it remains one, solid construction.
This is what Piet has done in his build. I have just overlaid these planks as means of illustration.
However, in my case, if I had used this method as above, the door was too high in relation to the canopy. (In this picture it actually looks as if the door is protruding above the company, but in reality that it was lying flush with the top edge.) Whilst I have seen one or two WB builders who used the doors as above, I was not happy to do so. Therefore, I went a different route.
I separated my door post from the door and cut off the bottom part. At the same time I stained the door post with Dark Oak – the fact that I had separated the two parts and stained the door post while not attached to the door, obviously prevented the stain from overflowing onto the door. After the stain had dried, I glued the door frame back around the door.
Here you can see my modified construction (on the left) compared to the standard kit one. Note that my modified door now was markedly lower compared to how it came out of the laser cut sheet.
Test-fitted, my modification had the desired effect as the door assembly now fits neatly underneath the upper edge of the canopy.
Now I could make a start by planking the sides (the area demarcated in red) using 1.5mm x 6mm walnut planks. They are planked in an overlapping (schotelende) way made easy by the notches in the outer wall post.
Before I started the planking though, I dry-fitted the door and then glued the inner wallpost into position - again making sure it was plumb and butted up tightly against the door.
With the two side walls planked up to this point. I could make a start with the center section.
At this point, I decided to glue the doors into the walls so that they were secure. I thought that that would make it easier then to close the gap off at the top.
But this obviously meant that I had to prepare the doors for installation and that meant hinges and door handles/knobs. I made a decision prior to the build, that I was not going to use any blackening fluid or paint. I could have used brass strips for the hinges, but against the very light-colored doors they just did not show up properly. I thus delved into my wood stash and cut two hinges out of very light-colored pear wood. The idea is this: I know that the tung oil, when applied, is not going to change the color of the door much, but tung oil darkens pear wood considerably. So when the whole assembly is treated with tung oil, the hinges will become a lot darker than what they are now while the doors will remain (more or less) the same color. It was thus more a case of insinuating the hinges rather than having sharply-defined hinges in place. The door knobs were easy - Kolderstok-supplied nails.
If the hinges do not work satisfactorily for me, I can always remove them and do something else. They are still easily accessible and since they are just tacked with PVA glue, removing them will be a cinch. Note the uneven lines at the bottom of the doors. They were sanded to fit in with the curvature of the deck.
With the doors in place, the top could be closed. Here I edge-glued two 1.5 x 6mm walnut planks together (the opening at the top was too big to use a single plank) and then filed out the openings for the door tops. This took ages to get it right.
And gluing that final clamp into position was even more fun. I quickly realized that I needed a third hand so I asked the Admiral (very nicely) to pull-up a chair opposite me and to provide the third hand/finger for an hour while I whispered sweet-nothings into her ear! :D
When the glue was dry, it was a case of filing and sanding the top edge of the plank flush with the top edge of the canopy. And finally, when all was said and done, this is where I am tonight.
Many many hours from now, I will go to bed a very happy Willem Barentsz builder. Never in my wildest dreams would I have imagined that I would get this far in two months. I have thoroughly enjoyed myself and my satisfaction of the build has only been surpassed by the wonderful participation of all of you. Until next time, take care, keep safe, cherish your loved ones and happy shipbuilding.
Good morning Heinrich. That is looking fantastic. Really outstanding work in 2 months. Enjoy it. Cheers
Thank you very much for the very kind words and wonderful support all along the way, Grant. It was and is very much appreciated. Yes my friend, I am happy, but today I can also feel that I've pushed hard - the ole' man is a wee tired. :)
Unfortunately that's what you get, not listening to your body at your age... ;)
I know Johan. And the worst is that I have cleaned the house this morning and now I'm really breaking down and cleaning up the shipyard. Not a nice thing to do - there are many good memories that I have built up there over the last four years. :(
Sterkte Heinrich, not only with the cleaning though; partir c'est mourir un peu, is what the French say.
Hello Heinrich, It is always sad to see the closing of a great ship yard, but one has to do what one hast to do. I am sure that your New Ship Yard will turn out very nice ships in the near future. With Anna's help you will be up and running again in the near future.
Regards Lawrence
Regards Lawrence
Thank you very much Lawrence. Yes, I try to humor myself by saying that I am just exchanging one shipyard for another. Admiral Anna though is a moot point. The school and my new apartment is in the Developing Area in Nantong, which is very far from her work. It will be impossible for us to be together during the week as the travel time for her will just be too much of an issue.
Probably so. I know some siding is tapered but is also rabbeted along its length.
That is very interesting Phil. I have never seen any of the builders on Modelbouwforum do that, nor do the instructions call for that. But that is worth finding out and I will do just that. Thank you for some very interesting information!
Sure! But some folks will go that extra mile and try their best to maintain authenticity and scale..
Hi Phil
I tried my best to find out more information with regards to rabbeting and/or tapering of overlapping planks on Dutch ships. I know for a fact that this is noty done on Kolderstok's models so I looked at two very highly detailed scratch builds of the Zeven Provincien by yet another Hans (@Hoosterw) and by Russian Master builder Narim Maygeldinov.
@Hoosterw Zeven Provincien
This build was and is extensively researched and based on the books of Otte Blom. Seeing that Hans has all the tools at his disposal to create both tapering and rabbet lines, I believe that if he found evidence of that, he would have incorporated it.
Narim Maygeldinov
In none of the above pictures is there any evidence of this.
However, bear in mind that the notched door and wall posts DO create a type of rabbet as the top of the planks lie absolutely flat in the notch and then tapers out towards the bottom.
These pics do not prove anything but then again I couldn't find any proof to the contrary either. But ... if these two gentlemen did not incorporate it, then I am happy that I am at least in good company. :)
That’s lapped cedar siding however with 1.5 to 2 mm thick stock on the model cutting a rabbit would be a challenge as would tapering the piece. Not saying it couldn’t be accomplished just sayin’ :)
Hi Ron. Please see my reply to @Philski Phil.
