Thank you for the very kind words my friend - it is always special. About the ruler - actually I can't take credit for that - that was included in the kit, so I am sure that both Ron and Jan are also the proud owners of a wooden ruler! :)
Alas, I don't have a wooden ruler in my kit, but I do have all the Walnut pieces that you have carefully assembled into a beautiful little ship.
Thank you very much my friend! It is sincerely appreciated! I was actually thinking about you, because you have seemed to have been quiet on the forum lately. I hope all is OK - have you started with the Statenjacht yet? By the way, I pester Anna every day about whether a postman has come knocking! :)
Unfortunately life has gotten in the way lately with the Admiral's condition so nothing has advanced with my building. Also, I have yet to receive a tracking number which concerns me. I will continue to inquire as to the status. I do continue to monitor the forum I just don't have anything to contribute right now.
Ron
Hans probably included the ruler because he knows I'm far-sighted and struggle to read the markings on metal ones! :) The walnut pieces are the important ones to be included! ROTF
Ron
My friend, I am not going to press the "like" button on your posting. I was afraid that something might be amiss with the Admiral and that that was the reason for your silence. I'm hoping and praying this side that things will go better soon and that you can become active once again in the shipyard.
The tracking number is strange though. You should have received that a day or two after sending the package. Ah well - let's keep the good faith!
Hello Dear Friends
It's the end of the week ... and ... the ole Nantong Shipyard ain't finished just yet. It will teach me never to say never. In between packing and preparing classes like it is going out of fashion, I just could not keep my hands off the Willem Barentsz. Every night, I would glue one or two planks, cut here, sand there, file a little and by the end of the week, I had completed yet another section. :D. This was really not planned, but I just cannot keep my hands off this little ship.
After reading that first paragraph I have visions of Heinrich in the moving van, enroute to his new place, sitting on packing boxes still working away at the WB :D .
Your work continues to inspire Heinrich.
Thank you for the kind words about the inspiration Roger! You are not too far off with me sitting in the back of the moving van. :D I will probably have to do just that to keep my real monster from being damaged!
PS. Please excuse the mess - things are hectic here with all the packing.
Wow, haven't looked at the forum much and had 3 pages to catch up with! Glad to see things are moving along in a positive direction for you Heinrich!
Thank you Glenn - hopefully I'm close now to achieving some form of normality! :)
Hello Dear Friends
In the logical sequence of the build, the next step was the final stage of raising the bulwarks' height at the stern and covers the area from where the D-Deck begins to the actual stern of the ship. In the photographs below of @pietsan Piet's build, this area is encircled in red.
Photograph: Piet Sanders
Photograph: Piet Sanders: This would then also entail adding the final bracing to the inside ...
... covering up the open section between the two ends of the bulwarks at the end of the stern and placing the coat of arms of the City of Amsterdam.
The procedure was simple enough: Edge glue two 1,5mm x 6mm walnut planks and one 1.5mm x 4mm plank which acts as an insert (so that you would have two sets for either side), cut them to the correct size and shape, double-plank them on the inside with three 1.5mm x 4mm walnut planks and cap them at the front and top with two 2mm x 3mm walnut strips. In total, one side is thus made up of 8 planks !!!:eek: The super-macro close-up below will illustrate what I mean.
Black Numbers and Arrows: Numbers 5 and 3 indicate the two 1.5mm x 6mm walnut planks, while #2 indicates the specially-shaped 1.5mm x 4mm walnut plank which acts as an insert. Bearing in mind that these all receive an inner planking, this makes for 6 planks. #4 indicates the 2mm x 3mm plank that caps the front of the bulwarks and #1 indicates the 2mm x 3mm plank which caps the top which makes the total number of planks in this little section 8!
The psychedelic green numbers :) and arrows refer to the two 1.5mm x 4mm planks and one 1.5mm x 6mm walnut planks that were used to make up the cover-piece right at the stern. Again, this is double-planked, so we are talking about 6 planks that make up that little piece.
Looking at this super-macro now, I am super-happy with the outcome! :)
As an indication of the scope of this little exercise - 22 planks went into finishing a 6 cm section. Then of course, we still need to add the six pieces of 2mm x 3mm walnut that form the inner bracing.
As per the instructions, I placed the frame (made up of 2mm x 2mm walnut strips) around the door section and placed the Coat of Arms. I believe it is only appropriate that the arms were raised in the old shipyard as a final tribute to my many happy hours that I spent here. BottleExplosion
Overview of the completed rear bulwark section.
Top View
Starboard view in natural light.
And the obligatory rear three-quarter view!
A long time ago in South Africa (I have no idea whether it also ran in other countries), Toyota had a marketing jingle which read : "Everything keeps going right ... Toyota! Each time I have completed a section of work on the WB, this jingle comes to my mind as everything about this build just keeps going well. Please note that this has nothing to do with my abilities - it is DESPITE my limited ability and therefore it says a lot about how this kit has been designed. I have no illusions about the fact that she will still have a few challenges for me, but for now ... everything keeps going right ... and I'm enjoying it immensely! :)
She looks beautiful Heinrich! Keep up the good work! ;)
Ps - what’s the word on the Fluyt? Have not heard anything lately.
I checked the site, it looks like it is available! However there were two choices. 1) basic blocks 2) authentic blocks
Not sure what that means? Is it referring to wood? And what is the difference between basic and authentic?
Thanks for any clarification you can give me on this. Or perhaps Hans can chime in! ;)
Thank you very much my friend - I appreciate the kind words on the WB!
Hans has waited for the boxes to be finalized and this has been done now.
On the website https://kolderstok.com/en/products/fluytschip?variant=42503870284019 the model is advertised at €365,00 with a delivery time of 8 to 10 working days. Maybe @Kolderstok Hans can confirm that.
Geez but you are fast! :D:D Authentic blocks simply mean that they are historically very accurate in shape and size, and of higher quality in general than the standard ones. I ordered the authentic blocks for the WB.
@Kolderstok Hans, where are you?
