Dear Friends
So no good talking about things - let's put it together and see what it looks like.
I started by putting together the actual windlass (braadspil).
Then I took some dry shellac and mixed it with the highest-content alcohol I could find (95%).
Which then resulted in this solution.
The windlass then received two coats of shellac,
After which the wood became darker and - I think - created a "warmer" atmosphere.
Now if you thought that space was at a premium, it gets worse. The whole assembly does not fit into the space behind the foremast. I sacrificed one piece of round wood, by cutting it to a length that would protrude slightly higher than the belaying rack so that I knew exactly where and how deep to file a groove into the belaying rack. Now all fits as it is supposed to.
And then this is what the whole assembly looks like dry-fitted.
So this where I am tonight. You know me - I don't expect you to pull any punches. Let me hear what you REALLY think - I value your opinion and especially your criticism if any.
@Kolderstok Hans is this what it should look like?
@Ab Hoving Ab I need your opinion here in the only way that you give opinions - from the hip and straight!
