I have filled my SCUBA tanks and jumped right in.
I used the standing tie block for the spreadsail yard as my test piece.
The kit instructions allow for using a big loop around the mast because that would be very easy to slip on over the heel of the mast on a model. Not so easy on the real thing at sea though.
The big loop requires two fictional chocks to stop it slipping down like Nora Batty's stockings (That's a joke for the Brits, sorry). The tackle is shown correctly though with the eye at the foot of the standing block.
Goodwin's AotS is a little more detailed but shows the loop around the mast as a fixed length. That's like trying to hold your trousers up with a belt without a buckle and no means of adjustment.
And here's the 'buckle' as shown by Longridge. I'm repeating the picture as we have started another page.
I'm feeling a little bit of a luddite today. He dropped in for breakfast.
No, seriously, I didn't want to use the big machine I was playing with yesterday. Longridge didn't have one so I don't need one. I used a vice with which I held a drill bit for the 'eye-splices' and a pair of self-closing tweezers (not shown in the photos) with which I expected to use to hold the block itself but in the event, never did.
Step One. Making the eye-splice. This time I tied a half hitch to start the 'seizing' and then took the ends over a few times. All secured with CA glue (superglue).
I discovered that if I used a long enough length of seizing line I could hold one end in my left hand, and the other in my mouth - keeping everything tight while my right hand applied the tiny tiny tiny drop of CA to the knot.
Step 2. The block is inserted between the strop lines and CA'ed into place. Glue marks on the block don't matter because I'll be shellacking it later and that makes CA stains invisible.
Step the Third. The seizing is started with a half-hitch and CA'ed.
Fourthly. The seizing is wound around the line. I find it best to go in the opposite direction to the twist of the thread of the strop. When I follow the twist, the seizing line drops into the groove between strands and leaves gaps.
Chapter V. The drill bit from the side of the vice allowed me to use gravity to keep things tight while I made the second eye-splice, the 'buckle of the belt'. While tying the 'seizing' around this the lines were held tight by clipping small clamps to them.
Next. The spare end is cut from the eye-splice and the tongue of the belt threaded through the buckle. Oh my!
Antepenultimate Part. The block was carefully positioned in the place indicated on the kit scale diagram and the belt pulled tight. The eye splice is marred by the crusty CA residue. This is general purpose, slightly thickened CA and next time I'll use the watery version. I think that will soak in better and look neater. (Oh, I havent applied the shellac yet. That might make the crystaline CA less obvious if it fills the airspaces. I'll let you know.)
Penultimate Stage. The end was arranged parallel to the loop around the mast as in the large Longridge diagram which Serbey and I posted yesterday, and glued into place. The CA here hold the lines neatly together and also secures the whole thing to the mast. The end was very carefully cut off.
Final destination. Three fake seizings were drawn on with a fine permanent parker. I think that black paint would be more convincing and would avoid the chance of ink bleeding into any alcohol or spirit based finish applied later.
Doing it the way it was done for real (with appropriate cheats) proved to be far easier than yesterday's attempts to do it the 'easier' ways. The block is exactly where I wanted it and I'm confident that it will stay there. Even if it doesn't I can fit another one in a few minutes even in a gale or during a battle.
Sergey, did you know that you would provoke me to improve my technique like this? I think you knew exactly what effect your post would have on me.
