HMAV BOUNTY - A “face lift “
Ha! Found your new thread Grant, and your new ambitious venture ... Voyage of the Bounty :)
Already looking like a huge success, great work meneer Thumbsup
Good morning Mark. Thank you. It has been quite the challenge trying to do this at a zero spend however the most fun I have had building a model. The outcome is not the best but way better than I expected when I started. It’s rather satisfying finding scraps of wood and laminating say a 2x4 strake together - and it works ok. The only disappointment is it does not hold its edges when cutting or shaping nor keeps a perfect circle when drilling. So the details fail a tad. Anyway fun. Cheers Grant
Good morning : Ricochet Rabbit at it again.
Struggle time:p. Still maintaining a zero cost however starting to feel the painROTF
Attempted to make a capstan :
818D977F-16CA-4149-9F3E-79C6D68DE782.jpegE44CD3B0-E19B-4B98-9A02-CF5371C37A30.jpeg79955D8B-28B6-4E5B-9189-74CBAB18CFA6.jpeg4B1AAFAF-82AF-4E3B-9791-18BE62DCE551.jpeg
Cleaned up the old anchor cable guides and used the old brass porthole windows, blackened for the cable holes :
Cleaned up some of the swivel guns (takes a long time to get the paint, varnish and CA glue off) re shaped the handle and added some trunnions. These are still WIP.
606916C9-234B-46F2-AD61-D27D8832C27A.jpeg6C2977F1-0395-40CF-A2A2-2E94216E358A.jpeg1FACC0AA-BEAB-45F6-9012-09F30A59F139.jpeg3B99C3F8-C2E6-455E-9C29-3E901DFECE13.jpegA8181C40-D474-4380-98EA-AEC7CEEE6864.jpegFB98320B-AF35-4BF0-B728-1E9D24B35692.jpeg
Nothing is glue in yet.
Hmmm- the quest continues.
Cheers Grant
Wow, the no cost bet/venture must be draining your "I might use this sometime stash" :D
Good morning Jan. It is getting near its end. :D . This is how I have managed so far :
1. I use the previous kit part, cover with veneer (which I have an endless free supply courtesy of a buddy who owns a kitchen business). I have to sand the veneer down to almost nothing or I increase the scale of each part by a mm. Here I’m making a channel.
2. I make wood by laminating the veneer and then cut to size. Most of the ship is built from this.
3. For solid wood I have used the solid walnut left from my Xebec - again cut to size.
4. I have a few bits from the Victory left.
Definitely not the best and I do struggle getting detail and sharp edges/notches etc from the laminates. Us South Africans are a stubborn bunch and “n Boer maak n plan” is part of life;).
Onwards we go:D
Cheers Grant
Onwards we go:D
Cheers Grant
Hi Grant.
That is resourceful, ingenious and inspiring. I’m fascinated by what you have managed to accomplished.
Jan
Hi Grant,
I had to read about your MTB accident and I wish you a speedy recovery and a successful operation in September.
As for your construction/facelift, I am still impressed with your work, what you do is indescribable and all of that so far for absolutely nothing.
Hi Grant,
Good morning Tobias. Thank you kindly - have an awesome holiday in Croatia. I am envious- absolutely love Croatia. Cheers Grant
Good morning. With my injury my shipyard time is increased however I am jumping around like ricochet rabbit on steroids. I can’t bring myself to finish any one thing. Full throttle……see what happens when I don’t get my adrenaline fix ROTF .
Channel- deadeyes- strops and chain plate:
I designed and 3D printed the deadeyes as I don’t have any 6mm dead eyes in my stock. I used the old chain plates however these are sooooo inaccurate. They look good tho. I am not sure these will remain so. May decide to make more accurate ones with some wire.
Started making the sheaves for the main yard sheets. Got bored :
So rigged my steering and tiller. 0F59743A-9865-4980-985B-5C8FA7E22F96.jpeg9D44DA3E-A93E-4538-A5E7-70E324A2F9E5.jpeg882D1483-FD99-44D0-8DAE-8BC2A396CA43.jpeg
I also printed 30 belay pins. These don’t look as good as the brass blackened pins but I am still in the zero spend category. They are resin printed and brittle so I will have to careful when rigging. Not glue in.
I need to STOP and fettle!!! HelpROTF
Cheers Grant
