HMS Agamemnon (1/64 Caldercraft)
Thank you all for your reactions and for watching.
In the meantime I placed some more rings on the deck. And made some nails to
Some detail to the deck.
So I started with the bow. And made a start with the upper knee and cornice, which I milled out slightly to give it some grace.
I made the grids fit further and placed the front deck plus made the skirting boards for the front bulkhead.
And I made the roofs of the roundhouses, I also wanted to add some elegance, so I made a frame of I profile, and glued it to the front. And made the remaining mouldings.
All this still needs to be painted, and will be placed later on.
Below some pictures, which speak louder than words.
everybody thanks for the looking and thumbs up.
And we continue a bit more.
I made the necessary mouldings and supports, and adjusted the bow to make it more in line with the figurehead.
View attachment 295633View attachment 295634View attachment 295635View attachment 295636
Caldercraft really do make good kits. The figure head (I’m assuming kit provided) is great comparable to what I have seen elsewhere. Cheers
Thanks to everyone for the likes and watching.
Little to report so far, recently I've been busy detailing the figurehead, thought the figurehead looked a bit rough, so after many hours of looking through a magnifying glass and sore fingers, I've used an engraving pen and some key files, adjusted the image slightly so it looks better to me.
And I made a start with painting the figurehead, which took a long time to decide which colours to use, as there are many examples on the internet. With undoubtedly everyone's own motives.
I have chosen these colours because, in my opinion, they must have been colours based on natural raw materials which must have been used in that period.
But it is in any case a free interpretation of what I think it must have been like.
Below some pictures, so I would say judge for yourself,
the necessary finishing and treatment must still be done to work out the colours a bit better, but it will give you an idea.
1676F023-733E-4E3D-B0BE-50CBE20AB8FA.jpeg28E2C17E-A539-4DBE-BF9D-44E1359502DB.jpegD99ADABC-C8BC-4072-845B-5DA6CB075734.jpeg88FC34CF-8ECF-45BA-A118-119B0B103728.jpegAD3529EF-EA35-4738-80DE-44D9C114132F.jpeg4FF2F933-4AA6-4E05-9773-238020AA964D.jpeg394902B3-2B92-4B2E-B1F3-EE89F7D7A957.jpegD0E15331-797A-493D-947E-C2AB2A857AF0.jpeg
View attachment 297867View attachment 297868View attachment 297869View attachment 297870View attachment 297871View attachment 297872View attachment 297873View attachment 297874
Hello Boris- one of my favorite builds here - ( baby sister to the Victory) Great detailing, just wonderful, and I will follow with interest. Cheers Grant
And of course, thank you all for your reactions and for watching.
Still "quickly" made his right hand and spear.
I found the supplied spear/lance a bit on the coarse side, so I decided to make a new one. First, I removed the old one, and then I pierced his right hand (sounds very dramatic, but it wasn't that bad )
Then made a new shaft from wood.
And drilled out the spear point, so that the shaft fits well.
And then placed the right hand.
Now I can place the shaft in the hand, or remove it to prevent damage.
Will adjust the length later if needed.
Below some photos
F6F38400-F06E-489C-BE9D-7629746A9AC8.jpegA74056C8-0DE7-49AB-AF86-B04F31BF59FA.jpeg5CF625D6-5B2A-4F06-99E8-944A61B91726.jpeg2BE10377-D464-4097-A4FE-B8642DEF3418.jpeg
Amazing detail.
I look at all the excellent ships on this forum and it truly inspires me to push myself to do a better build, even if it means doing a part 3 or 4 times to get as perfect as my skill level will let me'
Thanks for the inspiration.
Below some photos
View attachment 298554View attachment 298555View attachment 298556View attachment 298557
Magic!
Thank you all for your feedback and watching.
still working on the galleon, made the toilets and placed them, also the "knight heads " a bit adjusted, that is to say made some fittings and placed them (eyes to later attach a block and 2 frogs)
I also started with the "boomkins", which I turned out of a piece of 4mm round,
These will be put in the front in a 65 degrees angle, for which I made and placed a rosette. To make it look a bit neater.
And then attached with a couple of brackets to the railing which I made of brass,
I will later place the blocks that are attached to the end of the boomkins.
Remains the railing and the so-called "cat heads" plus a number of decorative strips.
2A15E418-44DE-41E3-BE3C-A5FEECB1D1BC.jpeg691821DC-52F3-460F-9CEE-CA7AFA4B812B.jpeg68051F31-C0B6-49DF-9E51-5E82949FC76E.jpeg8E468BDB-AB88-4FDA-A112-75E681A7F863.jpeg
Everybody thanks for the likes and watching.
Went a bit further with the galleon, and made the catheads,
As there is little mention of them in the building description, I took a number of contemporaries, including the Victory as a guide, and came to the following.
and made the last mouldings and gave them a colour, also gave the rest of the construction a colour.
Only the railing remains to be made, and then the galleon chapter is finished.
Below some photos.
7A6E8F54-DC67-47BC-89FB-DDB2CDE3AFE1.jpegDA465288-2642-4D73-A769-AE5A69C34FD4.jpeg140288DD-B56D-4D6A-A2AE-C3C02B212B73.jpeg6A29C4C9-980F-4734-B68D-4C5B8462DC3F.jpeg532861BC-C6E9-42CD-8F63-EFB486E13EA7.jpeg7BCF2BBF-B8C2-49D7-9457-1844F2BC9296.jpeg
