HMS ALERT 1777 cutter POF by shota70 [COMPLETED BUILD]
good evening dear friends
Tonight after weeks of work I finished the first stage of preparing the planking, all the boards were installed :)
View attachment 354835View attachment 354836View attachment 354837View attachment 354838View attachment 354839View attachment 354840View attachment 354841View attachment 354842View attachment 354844
in the coming days I will proceed to the preparations of the next stage: installing the nails according to the following plan:
Good night and peace to all the inhabitants of our special planet
What an incredible undertaking, my friend. What an achievement, congratulations!
A nice personal touch with this planking pattern, Shota. Well done!
good evening my dear friends
Today I took some time off from planking because I'm trying to establish a good method for making the special nail heads with the disk. Today I focused on the preparations required to create the gunwale. The parts required for this are in plate 22 and their number is fl78-83 as detailed in the construction booklet.
I cleaned the sawdust in the milling areas on the board, cut and sanded. It is worth noting that the milling machine/cnc did not cut everything and there are openings that we had to open ourselves, also in the brochure there were two misprints of pair B and A.
Tomorrow I will continue with final sanding and start installing the gunwale
good night or day to all of us :)
Hello dear friends
It's already 01:00 am at my place, after the family dinner during which we celebrated birthday for my father, I sat down to work on the ship.
Today I focused on the creation of the gun window sill in the bow of the ship.
First I had to correct a mistake I made in cutting the frames, I cut them too short. So what I did was to cut it down to the height of the deck and glue a new part that would give the midrash height. then I adjusted and installed the window sill.
After I was satisfied with the result, I proceeded to take care of the parts that make up the gunwale. Working on the subject requires a lot of patience , because most openings require quite a bit of sanding and adjustments to the size and angle of the frames. For now I have dry installed parts fl 77-78, more to come. good night dear friends :)
today I proceeded to take care of the parts that make up the gunwale, and finished the one side. All the fitting is without gluing, but on dry fitting :)
I'm attaching pictures of the window sill from yesterday work
wish to all of us Peaceful and satisfied week
You've gotten yourself quite the challenge, dear Shota, but apparently one you're able to master. Thumbsup
I can well image that those cap railings must have been quite a challenge - especially seeing that the holes are not all opened. The dry-fit though, looks excellent. You can get out the glue my friend! :)
Very impressive Shota, I really like the planking and the idea of that open area.
thank you very much my dear friend's for the kind words, encouragement, likes & smiles :) :D
today I finished fitting and gluing the gunwale parts on the first side. Before doing the adhesive, I made/engraved a nice cant along the entire length of the gunwale.
After the glue dried I did some fine final sanding and then applied a layer of oil which gave the gunwale a deeper and more beautiful color in my eyes. Now I'm in the middle of working on the other side
I'm attaching pictures of the work
