HMS ALERT 1777 cutter POF by shota70 [COMPLETED BUILD]
Hello dear friends
I am slowly moving forward in the process, when this time I created The tops of some of the frames bollard type of head.
I'm using a Fine manual wood sanding - the first round and the second straight/rectangular. as well as in different density sandpapers
In addition, I made channels in the heads of three frames in the stern area, into which I will insert the upper and narrow railing.
It was a pleasant and fruitful weekend, I wish it to all of you my friends :)
View attachment 380026View attachment 380027View attachment 380028View attachment 380029View attachment 380030View attachment 380033View attachment 380034
Excellent fine filling work on those pieces.
good evening dear friends
First I would like to thank you all for the compliments, words of support, likes and smileys, I really appreciate it!!
Today I have completed the work on the upper part of the railing - bullwarks as well as the cannon exits. the upper transome with the top of the stern railing.the stanchions on the side.
I'll let you get an impression of the photos of the process in progress.
Good night everyone
20230618_200441.jpg20230618_200708.jpg20230618_225136.jpg20230618_225228.jpg20230618_225307.jpg20230618_225320.jpg20230620_200207.jpg20230620_204423.jpg20230622_212703.jpg20230622_212741.jpg20230622_212820.jpg20230622_212854.jpg20230622_212909.jpg20230622_213001.jpg20230622_213012.jpg20230622_213038.jpg
Today I finished making the first part of the upper deck.
My plan is to install only two fifths of the deck (the first - adjacent to the side of the ship and on which the guns stand, the second - the center of the deck where the openings and lattice to the lower deck are located). To allow the observer to see the parts of the lower deck.
this is the main work steps:
1. Preparing the boards according to the plan of the deck.
2. Pasting line by line.
3. Sanding the boards - sanding discs with a density of 80 to 400. And finally with steel wool.
4. Marking the pegs with a soldering iron head stand with a hole (diameter 0.6 mm)
5. I applied oil to the deck. and then color corrections on the side of the ship.
I will let you get an impression of the process and the results, I wish you a pleasant weekend
20230628_235639.jpg20230628_235658.jpg20230628_235738.jpg20230630_161113.jpg20230630_161120.jpg20230630_171843.jpg20230630_180530.jpg20230630_180536.jpg20230630_180544.jpg20230630_180550.jpg20230630_180640.jpg20230630_180650.jpg20230630_180653.jpg20230630_201148.jpg20230630_201155.jpg
Before I continue with the creation of the upper deck, I started the work on all the parts that are spread out in the center of the ship (from the bow to the stern - such as: the openings for the lower deck, trellis and winch). Today I started working on the winch so I can build the deck around it and on the small winch behind the main mast.
The bitt is shaped from two cherry strips glued together. The top you need to shape yourself. A round file and the sanding disk will do the job. burnishing the pewter parts and coloring the bitt parts.
I work on the winches at the same time to get the best use of time, when parts are waiting to dry, I work on the other parts.
I'm attaching photos of the process including the locations of the various parts in the kit to make it easier for those coming in line
I wish you all a good and blessed week :)
20230701_142759.jpg20230701_142857.jpg20230701_144728.jpg20230701_144830.jpg20230701_144936.jpg20230701_151004.jpg20230701_155745.jpg20230701_161222.jpg20230701_162309.jpg20230701_162322.jpg20230701_182901.jpg20230701_194605.jpg
View attachment 382317View attachment 382318View attachment 382319View attachment 382320View attachment 382321View attachment 382322View attachment 382323View attachment 382324View attachment 382325View attachment 382326View attachment 382327View attachment 382328
Good morning Shota. I love the winch parts and the re colour you got. I had to play a little catch up as I’ve been idle and enjoying the little bit of sunshine in Cape Town winter. Awesome work. Cheers Grant
Dear friends, thanks for the compliments and words of support, likes and smiles, I really appreciate it:)
Piękna pracą. Jakiego preparatu używasz do oksydowania metalowych części. Pozdrawiam Mirek
